Shopping Cart v2.1 (Freeware)
Requirements: PPC WM6 - NET CF v3.5; HTC Touch HD
Overview: The application is a simple list viewer which displays the preconfigured items as a bulleted list. You can have it open and save shopping lists but you can create or modify them on the fly to suit your needs.
You can manually type in items to add to the shopping list or you can type up a list in Notepad or something similar. If you want to import a list in the application just save the file as a text file with each entry separated by a carriage return (new line / Enter) and copy it to your device. Then, in the application click File and Open and browse to where you copied the .txt file.
When you tap an item (click it) it toggles strikethrough text style, in effect marking it as found.
It is designed for and works for the Touch HD as far as resolution is concerned.
To change languages:
Edit the Language key in the registry and enter the name of the Language file. Reference the screenshots for an example. So, if your language file is \Program Files\cRaCKwHoRe's\Shopping Cart v 2.1\Languages\German.txt, then enter German. This is case-sensitive! To create your own language file just copy the existing English.txt file and edit the fields within it, rename it (with a .txt extension), and save it to the Languages folder.
To change the color of checked / unchecked items:
Firstly, the registry key MultiColorFonts must be set to 1. Then, edit the registry key(s) CheckedItemColor / UncheckedItemColor shown in the screenshots. The values you enter are the RGB values ranging from 0-255 (decimal, not hex) for each value (R, G, B). The defaults are red for unchecked items and gray for checked items. The registry location is HKLM\Software\cRaCKwHoRe's\Shopping Cart v 2.1\.
Update Description:
v2.1 (04-05-2009):
- Fix startup issue for alternate language roms.
- Remove scrollbars but still allow scrolling, to be more like other touch-sensitive scrolling applications.
- Ability to customize the color of checked / unchecked items if MultiColorFonts is enabled.
- Multiple language support.
- Moved application settings into registry rather than .xml file.
v2.0:
- Aesthetic overhaul thanks to Rozenthal.
- Checked items now move to the bottom of the cart. Unchecking them moves them back up.
- You have a choice now whether you want items to be marked strikethrough or not once they are marked off.
- You have a choice to use color-coding when marking off items. Marked items are greyed out and unmarked items are red.
- Item names in the cart can now be longer. Minor issue with the checkbox overlay but working on it.
- You can now edit a saved list after importing it.
- Application can be installed to main storage or storage card now.
To edit the application settings browse to where you installed it (either \Program Files\cRaCKwHoRe's\Shopping cart v 2.0\ or \Storage Card\Program Files\cRaCKwHoRe's\Shopping cart v 2.0\) in Total Commander. Select Shopping Cart.xml and click File, Edit. There are currently three settings and are explained within the .XML file:
(1) StrikethroughText.
(2) MultiColorFonts.
(3) PromptToSaveOnExitWithNonEmptyCart.
v1.0:
- Initial public release.
