SMS Settings 01
    [RELEASE] SMS Settings 01
    There are a few apps that do the same as this floating around, but most have requirements like .Net CF 3.5 or similar. This also gave me a chance to demonstrate my new set of controls for C++. (the slider, the buttons at the bottom etc.)
    What it does:
    Configures SMS Sent notification, SMS delivery receipts, Threaded SMS.
    It can be skinned (if you know what you're doing with res hacker) by editing l3v5yExtendedFunctionsResources.dll that should reside in \Windows.
    Install it, and restart your device. SMS Settings can be found under Start->Settings->System tab.
    Tested on my Diamond and Prophet, and in the WM5 emulators, so should work on all WM5+ Pocket PC devices.
    Note, SMS threading will only work on WM6.1 ROMs, since it's OS dependant...
    I TAKE NO CREDIT FOR THIS ORIGINAL THREAD HERE
    http://forum.xda-developers.com/showthread.php?t=514220
