phoneAlarm v216 beta (Build 351) beta
    [RELEASE] phoneAlarm v216 beta (Build 351) beta
    Your complete, easy to use, communication center, never overlook a missed call, voicemail, Email or SMS again. Plus 7 powerful Phone profiles to control all your important settings
    Supports WM 5.0, WM 6.0 and WM 6.1 Phone Edition (with touch-screen)
    phoneAlarm is a Today screen plugin - giving you total control over your Pocket PC Phone. Never miss an important call, SMS or Email again. Automatically switch profiles and quickly access Inbox, call history and control the state of bluetooth directly from the Today screen. Optimised for one-handed and in-car use.
    WM 2003 support is no longer available - you will need to use v1.67 (available for download here and contact us for a registration code after completing your purchase - you will get a free upgrade to v2.x if you upgrade device later
    phoneAlarm Lite is a simplified version of phoneAlarm still with all the MAJOR features, suitable for low-maintenance installations!
    See here for comparison
    Smartphone (no touch-screen) version is also available
    phoneAlarm Key Features
    Provides repeating alarms on new SMS, Email, missed calls, voice messages & reminders
    10 Custom Phone profiles with manual and automatic switching.
    Automatic profile change based on time, location, Appointment type/category, network and power/ActiveSync events
    Custom Email / SMS alarms based on text, sender or priority
    Alarm notification on weak battery and phone signal
    Customise sound, volume and options for each alarm type in each profile
    Automatically mute system and phone volume
    Skinnable user interface (How to create skins)
    Bluetooth and Flight mode control via profiles (also for Widcomm/Broadcomm stack)
    1-hand skin navigation and quick-dialer for last 10 numbers
    Gestures supported on skin
    Icons provide direct access to Inbox, call history etc.
    Task-switcher pop-up to close running applications
    Full dual SIMsupport (needs a v2.0 skin for all features
    English, German, French, Italian, Spanish, Danish, Norwegian, Swedish, Dutch, Czech, Polish, Greek, Hungarian, Russian, Japanese and Chinese user interface
    Fully supports VGA display and square screen devices
    Optimised for fast performance and maximum platform support ,
    Simple installation
    Additional features ONLY in Pro version
    Location-based information (change profile dependent on current location!) _
    Billing calculation - keep track of your phone costs _
    Detailed GPRS/Data volume tracking _
    Weather plugin with 4 day forecast
    Call and SMS forwarding support in each profile
    WLAN control via profiles
    Skin rotator element to display actual information
    Screen Lock is now almost finished, and I find it working REALLY well if I say so myself
    You activate/deactivate the via profiles - choose "phoneAlarm screenLock" for the locking option
    To unlock you have 15 seconds - not much time to play with unlocking - but should save lots of battery power for most users
    Still fine-tuning the button for gesture unlock, but should be pretty easy to use, (and lock.bmp can be easily replaced if you like a different button
  • COWHEAD
    MOY
    • Feb 28
    • 30
    • DIAMOND
    Re: phoneAlarm v216 beta (Build 351) beta
    thanks weesje im trying this out. this saus its a 15 day trial do you havw the full version?
    If you've been helped, hit the Thanks button.
      did you look through the zip files? every program released will have a way of registrationg whether it is a readme, nfo, keygen, crack, or patch
        hi now its my bad forgot the keygen addet to the first posted
        MODERATOR@SPJ
