LocateA latest software turns your Java enabled mobile phone, or your PDA Mobile Phone running Windows in to a personal real time tracking solution, which allows you to track people, employees, lone field workers or children etc, and the good news is it's free.
We also provide easy to use RSS feeds which enable you to capture your data to your own websites database so you can build and display your own maps with the provider of your choice, or if that sounds a bit daunting to you, don't worry as we have also provided an easy to use API... learn more...
real time tracking
GPRS 2 way messages / communication
SMS / Email geoFence alerts
reverse geo-coding to street / postcode
stores up to 10000 previous history tracks
full history searching
daily reports with graphs / distance traveled / top speed etc
traffic alerts
simple software download & setup, be on the map in minutes!
Have a look at the Global Map which shows everyone being tracked who chooses to be publicly displayed.
Our custom vehicle tracking map for same day couriers is another example of what we can offer you or your company.
Getting on the map is as easy as 1-2-3, we'll guide you through the whole process from start to finish, first you need to decide how you want to be tracked by clicking on the software download links below.
