Inesoft Phone v5.0 beta 6
Address Book is the best contact manager with Additional Phones and
Fields, Instant Search, Ring Tones, Photo Caller ID and Phone Profiles.
Inesoft Address Book - the most convenient way to manage contacts on
Windows Mobile device.
FEATURES
* Dialer
Using large size buttons you can easily dial a phone number or tap a new
SMS, add a contact or edit a number to your address book. Now you are
also able to find the contact when you remember the information partly
* Caller ID
All necessary information about the contact will be displayed at your screen
during the income call: the name and the phone number, contact’s photo
and even the company. Caller ID allows to turn on the loud speaker, to
make a callback, to turn off the sound (ring off) or to send an SMS in one touch
* History
Includes the history of the phone calls and the history of the incoming SMS
as well. It is also possible to group calls from one person, to view the
phone calls duration and to get the calls statistics on a certain contact
* Favorites
You can add as much contacts to Favorite list as you wish. Set up the
appropriate size and the number of Favorite contacts that will be displayed at the phone screen
* Profiler
Using Inesoft Profiler you are able to set up: the tone volume and the
vibration level for the each profile, profiles auto switching, automatic SMS
replies, block phone calls from the certain group of contacts and much more
* Contacts
Now you can manage your contacts and improve your address book: upload
a photo, add any information about the contact to the info fields, create
additional info fields and set up the type for them. Use T9 Search to find the necessary person.
* Additional Options
Inesoft Phone supports such unique features as: vibration when you press
the buttons to feel the touching; vibration after successful connection;
create block and allowed groups of contacts; get notification about unread
SMS and missed calls; set up the signal type for the group of contacts and much more
CHANGELOG
• Fix: BX. call: When you answer a call melody played for some time
• Fix: Profiles: if the profile specified external program to start, then when
you switch the profile to force the backlight turned kpc.
• Fix: Preferences: scroll hard. buttons allow scrolled off-screen
• Fix: Contacts: in the choice of the phone not draw the background of the buttons
• Fix: Contacts: no icon is displayed in the view of the contact
SUPPORTED MOBILE DEVICES
PocketPC2002/WM2003/WM2003SE/WM5/WM6
Phone Edition(Smartphone Edition is not supported)
VGA and QVGA in portrait and landscape mode
Register with any serial number
DOWNLOAD
FEATURES
* Dialer
* Caller ID
* History
* Favorites
* Profiler
* Contacts
CHANGELOG
DOWNLOAD
http://depositfiles.com/en/files/kb7f7893v http://letitbit.net/download/66e2966fa7109a9/IPhone.5.0.b6.rar.html
