WinRAR 391 BETA 2 with keygen 12/12
    [UPDATES] WinRAR 391 BETA 2 with keygen 12/12
    WinRAR is a powerful archive manager (Win32, Linux, Mac). RAR files can usually compress content by 8 percent to 15 percent more than ZIP files can. WinRAR is a powerful compression tool with many integrated additional functions to help you organize your compressed archives. It can backup your data and reduce size of email attachments, decompress RAR, ZIP and other files downloaded from Internet and create new archives in RAR and ZIP file format.
    WinRAR puts you ahead of the crowd when it comes to compression. By consistently creating smaller archives, WinRAR is often faster than the competition. This will save you disc space, transmission costs AND valuable working time as well. WinRAR is ideal for multimedia files. WinRAR automatically recognizes and selects the best compression method. The special compression algorithm compresses multimedia files, executables and object libraries particularly well.
    Features of WinRAR:
    - Using WinRAR puts you ahead of the crowd when it comes to compression by consistently making smaller archives than the competition, saving disk space and transmission costs.
    - WinRAR provides complete support for RAR and ZIP archives and is able to unpack CAB, ARJ, LZH, TAR, GZ, ACE, UUE, BZ2, JAR, ISO, 7Z, Z archives.
    - WinRAR offers a graphic interactive interface utilizing mouse and menus as well as the command line interface.
    - WinRAR is easier to use than many other archivers with the inclusion of a special "Wizard" mode which allows instant access to the basic archiving functions through a simple question and answer procedure. This avoids confusion in the early stages of use.
    - WinRAR offers you the benefit of industry strength archive encryption using AES (Advanced Encryption Standard) with a key of 128 bits.
    - WinRAR supports files and archives up to 8,589 billion gigabytes in size. The number of archived files is, for all practical purposes, unlimited.
    - WinRAR offers the ability to create selfextracting and multivolume archives.
    Recovery record and recovery volumes allow to reconstruct even physically damaged archives.
    - WinRAR features are constantly being developed to keep WinRAR ahead of the pack.
    Version 3.90 beta 1
    1. WinRAR version for Windows x64 is available. If you use
    Windows x64, it is strongly recommended to install 64 bit
    WinRAR version. It provides a higher performance and better
    shell integration than 32 bit version.
    2. RAR compression speed is improved for multi-core
    and multi-CPU systems. This improvement is most noticeable
    in Windows Vista and Windows 7 operating systems.
    3. "Remove duplicate folders from extraction path" option
    in "Settings/Compression" dialog is replaced by more universal
    "Remove redundant folders from extraction path" option.
    This option will eliminate redundant archive name based folders
    from extraction path if you unpack an archive with
    "Extract to DestName\" context menu command and if archive
    root folder contains only one folder and no files.
    4. Changes in "Extraction path and options" dialog:
    a) "New folder" button creates a new subfolder in currently
    selected folder;
    b) F2 key renames a selected folder in the folders tree;
    c) F5 key updated the tree pane contents;
    d) Del key removes a selected folder in the folders tree.
    5. You can enable "Show seconds" option in "Settings/File list"
    dialog if you wish to see seconds in file dates in file list
    in WinRAR shell.
    6. "Where to check for SFX archives" options group
    in "Settings/Integration/Context menus items" dialog lets
    you to control processing of SFX archives in context menus.
    For example, if you frequently right click ".exe" files
    on slow network disks, you can turn off "Network disks" options
    to minimize the delay before displaying the context menu.
    7. If you sort files by name in the file list in WinRAR shell,
    WinRAR will use the new logical file name sorting,
    same as in Windows Explorer, considering digits in file names
    by their numerical value. So files will be sorted as
    1.txt, 2.txt, 10.txt instead of previous 1.txt, 10.txt, 2.txt.
    This new sort behavior is available in Windows XP Service Pack 2
    and newer.
    8. Ctrl+W key combination can be used to close the main WinRAR window
    also as WinRAR viewer windows. "View as Windows text" shortcut
    in WinRAR viewer changed from Ctrl+W to Ctrl+I.
    9. New command line switch -r- disables recursion completely.
    So 'rar a -r- arc dirname' command will add only the empty
    dirname folder and ignore its contents. By default, if dirname
    does not include wildcards, RAR adds its contents even if
    -r switch is not specified.
    10. If used when extracting, the new command line switch -ai forces
    RAR to ignore file attributes. When using this switch,
    extracted files will always have attributes assigned by
    operating system to a newly created file by default.
    11. If output file name is not specified in "cw" command, console RAR
    will send comment data to stdout.
    12. When compressing stdin data with -si[name] switch, RAR sets
    modification time of archived entry to current system time.
    Previous RAR versions did not fill this field, resulting in
    meaningless modification time for stdin.
    13. Message displayed when you place the mouse cursor on WinRAR
    tray icon includes the archive name now. Previously only
    time left and total percent were displayed for archiving operations.
    14. Bugs fixed:
    a) WinRAR could fail to open tar or tar.gz archive if such archive
    contained a file larger than 8 GB;
    b) WinRAR context menu did not work properly in Windows 7 beta
    if icons in context menus were enabled and user clicked
    a file inside of Windows 7 Library folder;
    c) previous WinRAR versions failed to rename files having 5 or more
    continuous spaces in the name. WinRAR shell does not display
    such spaces for safety reasons, because they can hide an actual
    file extension. But this security measure prevented the rename
    command to work properly.
    Changes in version 3.90 beta 2:
    Delay between right clicking selected files in Windows Explorer and displaying the context menu is reduced. This delay can be noticeable, when you right click several thousands of files.
    Bugs fixed:
    Dragging a file over an existing archive in Windows Explorer did not work for 64 bit WinRAR;
    64 bit beta 1 shell extension crashed if user right clicked "Startup" folder in Start Menu and selected "Open" or "Explore" commands;
    "Scan archive for viruses" command in 64 bit beta 1 could fail to autodetect some of 32 bit antiviruses detected by 32 bit version;
    Beta 1 hung when the entire folder specified as a mask was excluded: 'rar a -xfolder arc folder';
    Sometimes beta 1 could hang when creating a new RAR archive if archive comment or one of advanced NTFS options was specified;
    ZIP encryption code was updated to include recent InfoZip fixes;
    64 bit version did not store the toolbar layout.
    Re: WinRAR 39 beta 2 with keygen
    bump bump new releas addet
    MODERATOR@SPJ
    • Tokey
      • Jan 10
      • 8
      • HTC Touch
      I had no problems downloading the prog. but when I try to open the key generator my computer doesn't allow it to open. What should I do?
        well give us more details please.... whats does it say when you are trying to open the keygen?
        • frenchw82
          • Mar 13
          • 19
          • HTC Mogul
          I deleted winrar off my computer and i can't open this file is there another way to get this on my computer? Maybe a cab file or am I screwed.
            there is no such thign as a cab file for a pc liek you ahve with a ppc...... a ppc cab file is a pc exe file..... what you can do is just go to the developers page and download trial from there and than use the included keygen provided and you will be golden.
              Originally posted by d/\sh
              there is no such thign as a cab file for a pc liek you ahve with a ppc...... A ppc cab file is a pc exe file..... What you can do is just go to the developers page and download trial from there and than use the included keygen provided and you will be golden.
              yeah just like that and he wil be golden
              moderator@spj
              • Tokey
                • Jan 10
                • 8
                • HTC Touch
                Norton Internet Security blocks it. It says the keygen contained a Backdoor.Trojan. Your computer is now secure. That's all.
                  disable norton than... norton picks up many false positives and this file is fine and scanned by myself.
                  • frenchw82
                    • Mar 13
                    • 19
                    • HTC Mogul
                    Thanks man I'll try that.
                      aight let me know if it works out for you.
                      • bigchico68
                        bigchico68
                        • Feb 22
                        • 186
                        • Touch Pro 2
                        The keygen file has a trojen in it. Luckily my security software caught it and removed it imediately. You have another keygen???
                        Get Your TP2 HD Wallpapers Here (Requests Available)
                        • mispook08
                          • 3014
                          • HTC Vogue (Sprint Touch)
                          #13
                          What security software do u have ?
                          • 1LOMOFO
                            • Nov 25
                            • 214
                            • htc
                            • 3
                            #14
                            That keygen is good, I installed this versoin a couple days ago. Avast picked it up on me to, but just let it go by and it will be all good. (It's a false positive, read a few posts before this)
                            • mispook08
                              • 3014
                              #15
                              He must be on norton lol gees this has been disscused so many times
