Paragon Software Interkey v3.0 Build 40.4526 Professional PPC w/Serial key Paragon Software Interkey v3.0 Pro
Supported devices:InterKey is compatible with Windows Mobile 5.0 Pocket PC, Windows Mobile 6.0 Professional & Classic, Windows Mobile 6.1 Professional & Classic devices and supports 320*240, 640*480, 240*240, 320*320 screen resolutions.
Overview: InterKey software provides multilingual onscreen keyboards for accurate text input.
Looking for handy onscreen keyboard in your own language? Need for effective text input tool and want to type using the finger as well as the stylus? In this case, InterKey for Windows Mobile will be the best solution.
InterKey software provides multilingual onscreen keyboards for accurate text input. InterKey expands the capability of using standard Windows Mobile keyboard by additional special features. With new version of InterKey you can use up to 60 national layouts and enter words just by hand thanks to large finger friendly keys.
InterKey is available in two versions for your choice: InterKey Standard and InterKey Professional. As optional feature, InterKey Professional provides word autocomplete function, which completes words as you type. Using this function greatly reduces the number of key presses and makes text input faster and precisely.
# 60 national keyboard layouts give you the ability to write in your native language. You can use multiple layouts simultaneously and quickly switch between the languages. For some languages additional alternative layout is available, for example, Latin American, Brazilian, US Dvorak, etc. Supported languages:
Albanian
Belarusian
Belgian
Brazilian
Bulgarian
Canadian
Catalan
Croatian
Czech
Danish
Dutch
English Estonian
Finnish
French
German
Greek
Hungarian
Icelandic
Italian
Latvian
Lithuanian
Macedonian
Mongolian Norwegian
Polish
Portuguese
Romanian
Russian
Serbian
Slovak
Slovenian
Spanish
Swedish
Turkish
Ukrainian
# NEW! Finger input allows you to enter words by using just a hand thanks to large finger friendly keys. A selected key is zoomed while writing release your finger to type it. If the wrong key is zoomed, slide your finger on the screen releasing it when the desired key is displayed.
# Special keystrokes known as gestures fully duplicate main keyboard functions (shift, backspace etc.) and allow you fast enter capital letters, spaces, erase the preceding character, go to new line.
# NEW! You can choose between standard keyboard layout and large keys for more convenient text input. Large keys are effective to use when typing with fingers rather than the stylus.
# Word Completion allows faster typing of frequently used words. Word autocomplete function simplifies text input by suggesting words as you type. Using this function greatly reduces the number of key presses. All new words, once entered, will be added to the word base. However, to reduce amount of storage used, you can delete word completion base for those languages you are not likely ever to use.
Note! Word Completion function is available in the Professional version only.
# Intuitive easy-to-use keyboards in InterKey dramatically reduce the mistakes when writing thanks to new ergonomic layout design.
# AltGrey key is supported for Croatian, Greek, Hungarian, Polish, Slovak and Slovenian keyboard layouts
Here are some key features of "InterKey Professional":
· InterKey Professional provides word autocomplete function that completes words you are typing on the on-screen keyboard or Pocket PC external keyboard.
· Possibility to install and use up to 60 national layouts simultaneously
· Custom on-screen keyboard look (standard, color, 3D look, size, etc.)
· AltGrey key is supported for Greek, Polish, Hungarian, Slovenian, Slovak and Croatian keyboard layouts
· Gestures function support (fast entering of capital letters, spaces, etc.)
· Quick switching between languages (when you use more than one language layout)
· Auto-repeat function (when a key is pressed and held, InterKey enters and
· continues to enter the appropriate symbol at regular intervals until the key
· is released)
]Downloads:
Albanian
Belarusian
Belgian
Brazilian
Bulgarian
Canadian
Catalan
Croatian
Czech
Danish
Dutch
English Estonian
Finnish
French
German
Greek
Hungarian
Icelandic
Italian
Latvian
Lithuanian
Macedonian
Mongolian Norwegian
Polish
Portuguese
Romanian
Russian
Serbian
Slovak
Slovenian
Spanish
Swedish
Turkish
Ukrainian
· is released)
http://www.penreader.com
http://3566ef5f.qvvo.com
