WVGA Zitoun ziPhone 01
    [Theme] WVGA Zitoun ziPhone 01
    HIN GUYS I TAKE NO CREDIT FOR THIS THEME
    https://www.youtube.com/watch?v=xUBARlqJRwg
    Summary of installation method. (remember to read the txt in the file):
    1. Install the latest version of Wisbar Advance Desktop 2
    2. Close all possible plug-ins (notably TF3D).
    3. Start WAD2. the default blue theme appears.
    4. Place the folder "ZiPhone" in: / Program Files / Lakeridge / Wisbar / Theme
    5. Return to the main screen. Long press and select "Settings"
    go to "icons" choose the path for the "Small Icon
    Directory: / Program Files / Lakeridge / Wisbar / Theme / WEATHER ZiPhone.
    6. Turn on the "General" tab and click "Change Theme".
    7. Choose "ZiPhone" and click on "Menu" and "Set as Portrait Theme". ZiPhone is now highlighted.
    8. Press "Apply"
    9. Confirm everything by clicking on "done" or "ok".
    10. A soft reset is recommended.
    Counseling:
    -Check the list of soft skinn to know which are used.
    -All apps must be installed on internal memory.
    -The weather update is done via web and wap (ie wireless or USB connection).
    You can also change the programs launched by different icons:
    1. Support long> Author mode
    2. Long press on the desired icon> Properties
    3. Press the "..." corresponding to the "Application / Folder to open
    4. Choose the program launch icon ...
