requirements: WM2003/WM5 (QVGA+VGA)
Overview: A skin suite for Wisbar Advance v2, PocketBreeze, Resco Keyboard, PsShutXP
developers page
http://nascasho.com/Skins-Sub-InD_05.html
A Revolutionary new skin exclusive by 3hc0.l3ad3r and Nascasho Designs. 5 Styles, your custom way, customization is key.
Available in VGA and QVGA resolution. This skin is a premium download and designed to be used with the upmost in quality. Add-ons and Updates are 100% free to people who purchase. Click the picture to hop over to my website to purchase. Note: Please type in your Email adress correctly, double or triple check that you spelt your email adress correct so that I can Email you the instructions how to download. (You don't know how many people don't check, lol!) Installation is simple and an included ReadMe.txt is available. Please wait 1-3 days for an email instructing you on how to download. Again, if you don't know why you haven't recived and email from me, you proably entered information wrong, double check!!!!! No refunds will be accepted unless it's for a good reason, aka, a bad one: "I cannot figure out how to open the skin, please give me a refund." It's clearly stated how to op-en and no problems should occur unless I see otherwise.
