Stopwatch v2.2 (Freeware)
PPC WM5, WM6 - VGA/WVGA display
It's basically a TouchFlo 3D inspired stopwatch that can take up to 10 split times, save and restore results in form of a XML file
VGA / WVGA displays ONLY !
To switch between timer mode and stopwatch mode you sweep your finger over either right or left.
You can use both mp3s and Wav-files as alarm sounds, but it is advisable to use short clips, since there currently is no way to stop a started alarm. (This means that a played song for example wont stop play until either the program is exited or the song is ended.) I am currently working on this.
It's basically a TouchFlo 3D inspired stopwatch that can take up to 10 split times, save and restore results in form of a XML file.
Update Description:
Version 2.2
- VGA and WVGA versions available.
- Bug when splitting times in advanced mode with d-pad corrected
- "Sleep mode"-bug corrected
- AppToDate support
More Info
Update Description:
Version 2.2
- AppToDate support
More Info
http://kaldma.se/programs/stopwatch/
