Well here it is guys, the finally waited Tachi phone canvas. It is so important for us b/c with this xbmod can finally finish the finaly version of tf3d2. All thanks to MikeKnoop over at XDA for this amazing work.
NOTE:
To installyou likely WILL need to close "cprog.exe" and install SDKCerts to install the cab. Also, I've been testing these by uninstalling my previous versions, soft-resetting, then installing the new one. Make sure you do the same! There are two versions gsm and cdma if u are gsm install gsm and vice versa.
Removed the rgu and settings from OEMs and CABs. Tested and text sending works on CDMA. This might also fix the PIN problem you guys were seeing (by the way, is the PIN problem at startup?)
Screenshots, OEMs and CABs for GSM/CDMA included in ZIP.
<DOWNLOAD FILE HERE>
ORIGINAL THREAD HERE
TACHI PHONE CANVAS KNOOP V2B =========================== Release: June 02 2009 Versions of OEMs included: =========================== Phone Canvas Enhancements: 4_10_34656_1 Slot Manager: 1_0_40519_0 Phone Canvas: 5_18_0_0 CHANGES: * Removed the SlotManager RGU and registry settings from OEM and CABs in an attempt to fix SMS sending issues ISSUES: * Conferencing does not work (due to not being able to put a call on hold) * left hard key (send) does not initate new phone call when typing ph. number (nor does the "talk" button) * Slider still a little flakey
http://forum.xda-developers.com/showthread.php?t=499076
