GPS Tuner version 5.4
Today we have released new version of GPS Tuner and Map Calibrator. This new version supports Suunto X9i data format, online Google Topo Map and Open Street Map downloading.
- 'Open Street Map' has been added as online map source
- 'Google Topo (Terrain)' has been added as online map source Pm
- Suunto X9i data format(.sdf) handling (Import and Export) has been added
- Automatic map rotation in 90 degrees has been added (instead of flipping 180 degrees)
- Built-in camera photo can be taken and added to waypoint directly
- Waypoints can be exported via TXT output module
Google Topo Map Map Rotation in 90 degrees
Adding picture using built-in Camera Open Street Map
Suunto SDF format export/impor
"GPS Tuner v5.4 and Map Calibrator v2.5 have been released. The new version of Award Winning off-road navigation software is now able to downlad Google Terrain (Topo) Maps and Open Street Maps from internet and use them without any calibration process. The new Map Calibrator also supports these new types of online maps. Suunto’s X9i off-road GPS watch data format (.sdf) is also supported, so you are able to see your X9i track in GPS Tuner or in Map Calibrator or upload your saved waypoints/routes to Suunto X9i internal memory. New map rotation mode (in 90 degrees steps) and built-in camera support are also implemented in GPS Tuner v5.4
NOTE I AM STILL LOOKING FOR KEYGEN OR SERIAL
