[070509] grooveROM 5 - CE OS 5.2.23003 (Build 23003.5.0.60) - [Diamond ROM
This topic is closed.
    due to excessive growth of thread here is the link with all information and download links.
    http://forum.ppcgeeks.com/showthread.php?t=60908
    Re: [060909] grooveROM 5 - CE OS 5.2.21806 (Build 21806.5.0.5) -- [Diamond
    This is a modified version of Calkulin's kitchen. Thanks to Calcu for the kitchen tools and OEM base. Thanks to lllboredlll for the custom kitchen.
    Here's a quick and dirty guide to cooking with the grooveROM 5 Kitchen:
    1. Download and extract the grooveROM Diamond kitchen to your computer
    2. Download and extract the latest grooveOEMbase [Diamond] to the root of the kitchen folder.
    3. Download the latest Diamond sys and rom folders here [21815], and extract to the root of your kitchen.
    4. You can manually remove any of the program folders in the OEM or SYS folders before cooking if you don't want that program or wait and do it with the kitchen if that folder has an "option.xml" file in it. If it doesn't, you have to remove it manually.
    5. If you want to add a program, you will need to find the OEM package somewhere at PPCGeeks (or elsewhere). Calu's kitchen has lots of OEMs that you can download. So does TobeyChris' kitchens. RSToyGuy also has a great thread in this forum with lots of VGA OEMs. Make sure that you delete and redundant files that are in the OEM folder when adding new ones. Redundant files cause errors when building.
    6. Run the Build Your Own grooveROM.exe in the root of the kitchen, then select Option 1 - Build a Custom ROM, then then BuildOS will open. Select the programs you want by checking the appropriate boxes. Once your done, click the green button in the upper left corner.
    7. Give it a few minutes to process. If there are any errors, that likely means that you have two of the same file somewhere in your OEM folder. Search for the file, and delete one of them - then re run BuildOS. Once Build completes by saying "done" in the bottom right, close BuildOS with the "x" in the upper right corner.
    8. A bunch of different programs will run for about five minutes or so, and then you will be taken to either a RUU (Rom Update Utility) or a PP (PagePool) changer. The PagePool changer is optional -- I'm using 24MB PP these days, but anything between 0 and 32 is fine. Close PP changer, the RUU opens.
    9. Flash and enjoy.
    **Important Notes:
    1. You must use my OEMdrivers folder with the SYS. If you seperate the two, you will need to add cprog.exe and tpcutil.dll to the sys.
    2. I don't care what you do with my kitchen. You can use any OEM's or files you find, but please give me the proper credit if you post a public ROM with elements of my work, or repost any files. Thanks.
    3. If you'd like to donate to me, please click here:
    If you want the grooveROM skinned Tachi Dialer, the OEMs are attached:
    grooveROM 5 registry edits
    grooveROM 5 has the following reg edits:
    REGEDIT4
    [HKEY_CURRENT_USER\Software\Microsoft\Today\Sprint.tsk]
    "Color_CaptionFlat"=hex:00,00,00,00
    "Color_CommandBar"=hex:00,00,00,00
    "Color_CommandBar_Highlight"=hex:00,00,00,00
    "Color_CommandBarSip_Highlight"=hex:00,00,00,00
    "Color_CommandBarText"=hex:ff,ff,ff,00
    "Color_CommandBarText_Highlight"=hex:ff,ff,ff,00
    "Color_Highlight"=hex:ef,ca,00,00
    "Color_HighlightText"=hex:ff,ff,ff,00
    "Color_NavBar_Highlight"=hex:00,00,00,00
    "Color_NavBarText_Highlight"=hex:ff,ff,ff,00
    "Color_SoftkeyBtnFace"=hex:00,00,00,00
    "Color_SoftkeyFlat"=hex:00,00,00,00
    "Color_SoftkeyFlat_Highlight"=hex:00,00,00,00
    "Color_SoftkeyFlatCenter"=hex:00,00,00,00
    "Color_SoftkeyFlatCenter_Highlight"=hex:00,00,00,00
    "Color_TitleFlat"=hex:00,00,00,00
    "Color_TitleFlatCenter"=hex:00,00,00,00
    [HKEY_LOCAL_MACHINE\Drivers\TouchPanel]
    "PressureThreshold"=dword:00001388
    [HKEY_LOCAL_MACHINE\Software\Opera\Preload]
    "RealExit"=dword:00000001
    [HKEY_LOCAL_MACHINE\Software\HTC\Camera\Captparam]
    "CaptureTimer"=dword:00000032
    "CapKeyDelayTime"=dword:0000000f
    [HKEY_CURRENT_USER\ControlPanel\Notifications\{A877D65A-239C-47a7-9304-0D347F580408}]
    "AvailableOptions"=dword:00000000
    [HKEY_CURRENT_USER\ControlPanel\Notifications\{A877D660-239C-47a7-9304-0D347F580408}]
    [HKEY_CURRENT_USER\ControlPanel\Notifications\{A877D661-239C-47a7-9304-0D347F580408}]
    [HKEY_CURRENT_USER\ControlPanel\Notifications\{15F11F90-8A5F-454c-89FC-BA9B7AAB0CAD}]
    [HKEY_CURRENT_USER\ControlPanel\Notifications\{A877D65B-239C-47a7-9304-0D347F580408}]
    [HKEY_CURRENT_USER\ControlPanel\Notifications\{695F6B37-EE99-489b-982D-F9A46A944ED1}]
    [HKEY_LOCAL_MACHINE\Drivers\BuiltIn\Battery]
    "PollInterval"=dword:00004e20
    [HKEY_LOCAL_MACHINE\Software\OEM\PhoneSetting\NetworkService]
    "ItemCount"=dword:00000003
    "ItemName1"="Sprint Only"
    "ItemName2"="Automatic"
    "ItemValue1"=dword:00000001
    "ItemValue2"=dword:00000004
    "ServiceName"="Roaming"
    "ServiceTitle"="Phone: Roaming"
    "ItemName3"="Roaming Only"
    "ItemValue3"=dword:00000003
    [HKEY_LOCAL_MACHINE\Software\OEM\InitProv\PhoneSetting]
    [HKEY_LOCAL_MACHINE\Software\OEM\WModem]
    "CheckProfile"=dword:00000000
    "Multi-NAI"=dword:00000000
    "WModemDUN"=dword:00000000
    [HKEY_LOCAL_MACHINE\Comm\InternetSharing\Settings]
    "MaxCMConnectRetries"=dword:00000000
    "ForceCellConnection"="Sprint"
    [HKEY_CURRENT_USER\Software\Microsoft\InternetSharing]
    "LastCellConnection"="Sprint"
    [HKEY_LOCAL_MACHINE\Comm\InternetSharing]
    "Extension"=""
    [HKEY_LOCAL_MACHINE\Comm\ConnMgr\Providers\{7C4B7A38-5FF7-4bc1-80F6-5DA7870BB1AA}\Connections\Phone as Modem]
    "Enabled"=dword:00000000
    "ConnectionGUID"="{E8F7941B-F379-E1C7-A25E-9C1425630A20}"
    "ReadOnly"=dword:00000000
    "SecureLevel"=dword:00000000
    "Secure"=dword:00000000
    "AlwaysOn"=dword:00000000
    "RequirePw"=dword:00000000
    "EntryType"=dword:00000000
    "DestId"="{ADB0B001-10B5-3F39-27C6-9742E785FCD4}"
    [HKEY_LOCAL_MACHINE\Software\HTC\Camera\P3]
    "MainCamSupportCaptSize"=dword:000006d0
    "MainCamCaptSize"=dword:00000400
    "Property"=dword:00200299
    "Enable"=dword:00000001
    "SaveFolder"="My Pictures"
    "EnableRecLimit"=dword:00000000
    "RecLimitSize"=dword:0000005f
    "RecLimitedType"=dword:00000000
    "EncodeFormat"=dword:00000002
    "CaptureFormat"=dword:00000002
    "CaptureType"=dword:00000005
    [HKEY_LOCAL_MACHINE\System\Versions]
    "Aku"=" grooveROM 5"
    [HKEY_LOCAL_MACHINE\Software\OEM]
    "ROMVersion"="grooveROM 5"
    [HKEY_CURRENT_USER\ControlPanel\Sip]
    "TurnOffAutoDeploy"=dword:00000001
    [HKEY_LOCAL_MACHINE\Software\Microsoft\Shell\TaskBar]
    "LimitedClock"=dword:00000000
    "ConsistentClockOrBattery"=dword:00000000
    [HKEY_LOCAL_MACHINE\ControlPanel\Customer Feedback]
    "Redirect"=""
    "Group"=dword:00000001
    "Hide"=dword:00000001
    [HKEY_LOCAL_MACHINE\Comm\TNETWLN1\Parms]
    "Dot11SupportedRateMaskG"=dword:00000008
    [HKEY_LOCAL_MACHINE\Software\Microsoft\Bluetooth\A2DP\Settings]
    "BitPool"=dword:0000003c
    "MaxSupportedBitPool"=dword:0000003c
    "UseJointStereo"=dword:00000000
    "SampleRate"=dword:0000bb80
    [HKEY_CURRENT_USER\Software\HTC\BootLauncher\Services\OutlookEnhancement]
    "Module"=""
    [HKEY_CURRENT_USER\Software\HTC\TaskManager\ExclusiveList\System]
    "repllog.exe"=dword:00000000
    "manila2.exe"=dword:00000000
    [HKEY_LOCAL_MACHINE\Software\Microsoft\CHome\CClock]
    "SK2URL"="CommManager;AppRunToHandleNotification"
    "SK2TEXT"="Comm Mgr"
    [HKEY_LOCAL_MACHINE\Software\Microsoft\CHome\CWindowsLive]
    "Disabled"=dword:00000000
    [HKEY_LOCAL_MACHINE\Software\OEM\PhoneSetting]
    "HiddenModeOperationPage"=dword:00000000
    [HKEY_CLASSES_ROOT\3gpfile\Shell\DRMOpen\Command]
    "Default"="HTCAlbum.exe \"%1\""
    [HKEY_CLASSES_ROOT\3gpfile\Shell\Open\Command]
    [HKEY_CLASSES_ROOT\3g2file\Shell\DRMOpen\Command]
    [HKEY_CLASSES_ROOT\3g2file\Shell\Open\Command]
    [HKEY_CLASSES_ROOT\mp4file\Shell\DRMOpen\Command]
    [HKEY_CLASSES_ROOT\mp4file\Shell\Open\Command]
    [HKEY_CLASSES_ROOT\WMVFile\Shell\Open\Command]
    [HKEY_CLASSES_ROOT\jpegimage\Shell\DRMOpen\Command]
    [HKEY_CLASSES_ROOT\jpegimage\Shell\Open\Command]
    [HKEY_CLASSES_ROOT\gifimage\Shell\DRMOpen\Command]
    [HKEY_CLASSES_ROOT\gifimage\Shell\Open\Command]
    [HKEY_CLASSES_ROOT\pngimage\Shell\DRMOpen\Command]
    [HKEY_CLASSES_ROOT\pngimage\Shell\Open\Command]
    [HKEY_CLASSES_ROOT\bmpimage\Shell\DRMOpen\Command]
    [HKEY_CLASSES_ROOT\bmpimage\Shell\Open\Command]
    [HKEY_LOCAL_MACHINE\Software\Microsoft\CHome]
    "Plugins"="CWelcomeCenter;CMusic;CMyPhotos;CPhone;CVoicemail;ATFavePeople;CText;CEmail;CClock;CHome;TitaniumWeather;CAppointments;Opera;CHomeFavs;CWindowsLive"
    "DefaultXML"="<Plugins Order=\"CMyPhotos;CMusic;CWelcomeCenter;CPhone;CVoicemail;ATFavePeople;CText;CEmail;CClock;CHome;TitaniumWeather;CAppointments;Opera;CHomeFavs;CWindowsLive\"  CPRFileName=\"Titanium\" DisplayStyle=\"Titanium\" />"
    "ExtensibilityXML"="<Plugins Order=\"CWelcomeCenter;CMusic;CMyPhotos;CPhone;CVoicemail;ATFavePeople;CText;CEmail;CClock;CHome;TitaniumWeather;CAppointments;Opera;CHomeFavs;CWindowsLive\"  CPRFileName=\"Titanium\" DisplayStyle=\"Titanium\" />"
    [code]
    <wap-provisioningdoc>
    <characteristic type="Registry">
    <characteristic type="HKLM\SOFTWARE\Microsoft\AddrBook" translation="filesystem">
    <parm name="Default_Area" datatype="integer" value="780"/>
    </characteristic>
    <characteristic type="HKLM\SOFTWARE\HTC\PHONE\PhoneExtendSetting" translation="filesystem">
    <parm name="EndCallTime" datatype="integer" value="0"/>
    </characteristic>
    <characteristic type="HKLM\SOFTWARE\HTC\PHONE" translation="filesystem">
    <parm name="EndKeyDelayInterval" datatype="integer" value="0"/>
    </characteristic>
    <characteristic type="HKCU\ControlPanel\PhoneExtendFunction\CDMA" translation="filesystem">
    <parm name="SignalStrengthLevel" datatype="integer" value="6"/>
    </characteristic>
    <characteristic type="HKCU\ControlPanel\PhoneExtendFunction\CDMA\F lightModeOnOff" translation="filesystem">
    <parm name="Sound_on" datatype="string" value="none"/>
    </characteristic>
    <characteristic type="HKLM\Ident" translation="filesystem">
    <parm name="Name" datatype="string" value="Diamond"/>
    </characteristic>
    <characteristic type="HKCU\Software\Microsoft\Windows CE Services" translation="filesystem">
    <parm name="DeviceFriendlyName" datatype="string" value="Diamond"/>
    </characteristic>
    <characteristic type="HKCU\ControlPanel\Phone" translation="filesystem">
    <parm name="CallProgressIdleTimeout" datatype="integer" value="0"/>
    <parm name="DoNotFilterCallLog" datatype="integer" value="1"/>
    </characteristic>
    <characteristic type="HKLM\Software\OEM\dim" translation="filesystem">
    <parm name="EnableMSID" datatype="integer" value="1"/>
    <parm name="EnableMDN" datatype="integer" value="1"/>
    <parm name="EnableESN" datatype="integer" value="1"/>
    <parm name="EnableCurrentChannel" datatype="integer" value="1"/>
    <parm name="EnableCurrentNetworkID" datatype="integer" value="1"/>
    <parm name="EnableDurationPage" datatype="integer" value="1"/>
    <parm name="EnableCurrentUserName" datatype="integer" value="1"/>
    <parm name="HideMIN" datatype="integer" value="0"/>
    <parm name="ShowProv" datatype="integer" value="1"/>
    </characteristic>
    <parm name="EnableOnePlusMDNVoicemail" datatype="integer" value="1"/>
    <parm name="Disable_ECall_Sound" datatype="integer" value="1"/>
    </characteristic>
    <characteristic type="HKLM\Software\HTC\VolumeOverlay" translation="filesystem">
    <parm name="MultiIncallSetting" datatype="integer" value="1"/>
    </characteristic>
    <characteristic type="HKLM\Software\OEM\PhoneSetting" translation="filesystem">
    <parm name="HiddenDeleteVM" datatype="integer" value="0"/>
    <parm name="HiddenPlusCodeDialingPage" datatype="integer" value="0"/>
    <parm name="ShowOutOfCoverageAreaAlertPage" datatype="integer" value="1"/>
    <parm name="ShowAutoPrependPage" datatype="integer" value="1"/>
    <parm name="AutoPrepend_1" datatype="integer" value="1"/>
    <parm name="ShowCallGuardPage" datatype="integer" value="1"/>
    <parm name="HiddenPreferenceMode" datatype="integer" value="0"/>
    <parm name="HiddenTimesyncPage" datatype="integer" value="0"/>
    <parm name="HiddenAlertPage" datatype="integer" value="0"/>
    <parm name="HiddenVoicePrivacyPage" datatype="integer" value="0"/>
    <parm name="ShowDNDModePage" datatype="integer" value="1"/>
    <parm name="ShowDataRoamDefault" datatype="integer" value="1"/>
    <parm name="DataRoamGuard" datatype="integer" value="1"/>
    <parm name="DataRoamNeverAsk" datatype="integer" value="2"/>
    <parm name="HiddenNAMSelectPage" datatype="integer" value="1"/>
    <parm name="HiddenModeOperationPage" datatype="integer" value="1"/>
    <parm name="ShowRoamingAlertPage" datatype="integer" value="1"/>
    <parm name="RoamingAlert" datatype="integer" value="1"/>
    <parm name="ShowCallGuard" datatype="integer" value="0"/>
    <parm name="ShowDataRoamGuard" datatype="integer" value="1"/>
    </characteristic>
    <characteristic type="HKLM\Software\OEM\PhoneSetting\OutOfCoverage AreaAlert" translation="filesystem">
    <parm name="EnableOutOfCoverageAreaAlert" datatype="integer" value="0"/>
    </characteristic>
    <characteristic type="HKLM\Software\OEM\PhoneSetting\PlusCodeDiali ng" translation="filesystem">
    <parm name="PlusCodeEnable" datatype="integer" value="1"/>
    <parm name="PlusCodeNumber" datatype="string" value="011"/>
    <parm name="ResetNumber" datatype="string" value="011"/>
    </characteristic>
    <characteristic type="HKLM\Software\OEM\PhoneSetting\DNDMode" translation="filesystem">
    <parm name="DND_Mode" datatype="integer" value="0"/>
    </characteristic>
    <characteristic type="HKLM\Software\HTC\HTCSettings" translation="filesystem">
    <parm name="BTPAN" datatype="integer" value="1"/>
    </characteristic>
    <characteristic type="HKLM\Software\HTC\DeviceInfo" translation="filesystem">
    <parm name="SetMEIDToDecimal" datatype="integer" value="0"/>
    </characteristic>
    <characteristic type="HKLM\Software\Microsoft\ActiveSync" translation="filesystem">
    <parm name="DeviceManufacturer" datatype="string" value="HTC"/>
    <parm name="DeviceModel" datatype="string" value="Touch Diamond"/>
    </characteristic>
    <characteristic type="HKLM\Comm\EAP\Extension\25" translation="filesystem">
    <parm name="ValidateServerCert" datatype="integer" value="0"/>
    </characteristic>
      REGEDIT4
      "Extension"=""
      "Redirect"=""
      "Module"=""
      [code]
      </characteristic>
      </characteristic>
      </characteristic>
      </characteristic>
      </characteristic>
      </characteristic>
      </characteristic>
      </characteristic>
      </characteristic>
      </characteristic>
      </characteristic>
      </characteristic>
      </characteristic>
      </characteristic>
      </characteristic>
      </characteristic>
      </characteristic>
      </characteristic>
      </characteristic>
      <characteristic type="HKLM\SOFTWARE\OEM\InitProv\PhoneSetting" translation="filesystem">
      <parm name="ServiceName" datatype="string" value="Network Service"/>
      <parm name="ServiceTitle" datatype="string" value="Phone: Preferred Serving System"/>
      <parm name="ItemCount" datatype="integer" value="5"/>
      <parm name="ItemName1" datatype="string" value="Home only"/>
      <parm name="ItemValue1" datatype="integer" value="1"/>
      <parm name="ItemName2" datatype="string" value="Automatic-A"/>
      <parm name="ItemValue2" datatype="integer" value="2"/>
      <parm name="ItemName3" datatype="string" value="Automatic-B"/>
      <parm name="ItemValue3" datatype="integer" value="3"/>
      <parm name="ItemName4" datatype="string" value="Standard"/>
      <parm name="ItemValue4" datatype="integer" value="4"/>
      <parm name="ItemName5" datatype="string" value="Roaming Only"/>
      <parm name="ItemValue5" datatype="integer" value="5"/>
      </characteristic>
      <characteristic type="HKLM\Comm\TcpIp\Parms" translation="filesystem">
      <parm name="TcpMaxConnectRetransmissions" datatype="integer" value="10"/>
      <parm name="TcpMaxDataRetransmissions" datatype="integer" value="10"/>
      <parm name="TcpWindowSize" datatype="integer" value="2451808"/>
      <parm name="Tcp1323Opts" datatype="integer" value="1"/>
      <parm name="TcpMaxDupAcks" datatype="integer" value="2"/>
      <parm name="EnablePMTUDiscovery" datatype="integer" value="1"/>
      <parm name="IGMPLevel" datatype="integer" value="0"/>
      <parm name="SackOpts" datatype="integer" value="1"/>
      <parm name="TimerWheelSize" datatype="integer" value="5"/>
      </characteristic>
      <characteristic type="HKLM\ControlPanel\WiFi" translation="filesystem">
      <parm name="ScanInterval" datatype="integer" value="180"/>
      </characteristic>
      <characteristic type="HKCU\Software\Microsoft\Windows\CurrentVersi on\Internet Settings" translation="filesystem">
      <parm name="MaxConnectionsPerServer" datatype="integer" value="16"/>
      </characteristic>
      <characteristic type="HKLM\Software\Microsoft\Windows\CurrentVersi on\Internet Settings" translation="filesystem">
      <parm name="ClearTypeText" datatype="integer" value="1"/>
      </characteristic>
      <characteristic type="HKLM\System\ErrorReporting\DumpSettings" translation="filesystem">
      <parm name="DumpEnabled" datatype="integer" value="0"/>
      </characteristic>
      <characteristic type="HKLM\Drivers\BuiltIn\ErrorReporting" translation="filesystem">
      <parm name="PollInterval" datatype="integer" value="1048575"/>
      </characteristic>
      <characteristic type="HKLM\Comm\AsyncMac1\Parms" translation="filesystem">
      <parm name="DisablePowerManagement" datatype="integer" value="0"/>
      </characteristic>
      <characteristic type="HKLM\Comm\PPTP1\Parms" translation="filesystem">
      </characteristic>
      <characteristic type="HKLM\Comm\L2TP1\Parms" translation="filesystem">
      </characteristic>
      <characteristic type="HKLM\Drivers\SDCARD\ClientDrivers\Class\MMC_ Class" translation="filesystem">
      </characteristic>
      <characteristic type="HKLM\Drivers\SDCARD\ClientDrivers\Class\NAND _Class" translation="filesystem">
      </characteristic>
      <characteristic type="HKLM\Drivers\SDCARD\ClientDrivers\Class\SDMe mory_Class" translation="filesystem">
      </characteristic>
      <characteristic type="HKLM\Drivers\Drivers\SDCARD\ClientDrivers\Cl ass\SIM_Class" translation="filesystem">
      </characteristic>
      <characteristic type="HKLM\Comm\ConnMgr\Planner\Settings" translation="filesystem">
      <parm name="CacheTime" datatype="integer" value="60"/>
      </characteristic>
      <characteristic type="HKLM\Drivers\Builtin\Battery" translation="filesystem">
      <parm name="PollInterval" datatype="integer" value="25000"/>
      </characteristic>
      <characteristic type="HKLM\SYSTEM\CurrentControlSet\Control\Power" translation="filesystem">
      <parm name="DisableGwesPowerOff" datatype="integer" value="0"/>
      <parm name="WakeupPowerOff" datatype="integer" value="0"/>
      </characteristic>
      <characteristic type="HKCU\ControlPanel\Backlight" translation="filesystem">
      <parm name="ACTimeout" datatype="integer" value="60"/>
      <parm name="BatteryTimeout" datatype="integer" value="30"/>
      </characteristic>
        <characteristic type="HKLM\System\CurrentControlSet\Control\Power\ Timeouts" translation="filesystem">
        <parm name="ACResumingSuspendTimeout" datatype="integer" value="21"/>
        <parm name="ACSuspendTimeout" datatype="integer" value="600"/>
        <parm name="ACSuspendTimeoutSave" datatype="integer" value="600"/>
        <parm name="BatteryPoll" datatype="integer" value="1000"/>
        <parm name="BattResumingSuspendTimeout" datatype="integer" value="21"/>
        <parm name="BattSuspendTimeout" datatype="integer" value="60"/>
        <parm name="BattSuspendTimeoutSave" datatype="integer" value="60"/>
        </characteristic>
        <characteristic type="HKLM\System\GDI\GLYPHCACHE" translation="filesystem">
        <parm name="limit" datatype="integer" value="131072"/>
        </characteristic>
        <characteristic type="HKLM\System\StorageManager\FATFS" translation="filesystem">
        <parm name="CacheSize" datatype="integer" value="8192"/>
        <parm name="EnableCache" datatype="integer" value="1"/>
        </characteristic>
        <characteristic type="HKLM\System\StorageManager\Filters\fsreplxfi lt" translation="filesystem">
        <parm name="ReplStoreCacheSize" datatype="integer" value="8192"/>
        </characteristic>
        <characteristic type="HKLM\Software\Microsoft\Shell\IconConfig" translation="filesystem">
        <parm name="HorizontalIconSpacing" datatype="integer" value="112"/>
        <parm name="IconTitleFontSize" datatype="integer" value="6"/>
        <parm name="VerticalIconSpacing" datatype="integer" value="115"/>
        </characteristic>
        <characteristic type="HKLM\Software\Microsoft\Calendar" translation="filesystem">
        <parm name="ShowLunarCalendar" datatype="integer" value="1"/>
        </characteristic>
        <characteristic type="HKCU\Software\Microsoft\Calendar" translation="filesystem">
        <parm name="ShowTextInWeekView" datatype="integer" value="1"/>
        </characteristic>
        <characteristic type="HKCU\ControlPanel\SoundCategories\RingPrevie w" translation="filesystem">
        <parm name="InitVol" datatype="integer" value="5"/>
        </characteristic>
        <characteristic type="HKLM\Drivers\BuiltIn\WaveDev" translation="filesystem">
        <parm name="AcousticFile" datatype="string" value="\Windows\AudioPara3.csv"/>
        </characteristic>
        <characteristic type="HKLM\Software\Microsoft\Bluetooth\A2DP\Setti ngs" translation="filesystem">
        <parm name="SampleRate" datatype="integer" value="48000"/>
        </characteristic>
        <parm name="UseJointStereo" datatype="integer" value="0"/>
        </characteristic>
        <characteristic type="HKLM\System\GDI\ClearTypeSettings" translation="filesystem">
        <parm name="OffOnRotation" datatype="integer" value="0"/>
        </characteristic>
        <characteristic type="HKLM\Software\HTC\SUPL AGPS" translation="filesystem">
        <parm name="GPSMode" datatype="integer" value="4"/>
        <parm name="EnableGPSSmartMode" datatype="integer" value="1"/>
        <parm name="ServerPort" datatype="integer" value="8889"/>
        <parm name="ServerIP" datatype="string" value="216.198.139.92"/>
        <parm name="QosPerformance" datatype="integer" value="89"/>
        <parm name="QoSAccuracy" datatype="integer" value="50"/>
        <parm name="TimeBetweenFixes" datatype="integer" value="1"/>
        <parm name="NumberFixes" datatype="integer" value="999999999"/>
        <parm name="EnableAGPS" datatype="integer" value="1"/>
        <parm name="EnablePDEIPFromNV" datatype="integer" value="0"/>
        </characteristic>
        <characteristic type="HKLM\Software\OEM\Power" translation="filesystem">
        <parm name="ShowMovingChargeBar" datatype="integer" value="1"/>
        </characteristic>
        <characteristic type="HKLM\System\GDI\Rotation" translation="filesystem">
        <parm name="HideOrientationUI" datatype="integer" value="0"/>
        </characteristic>
        <characteristic type="HKLM\Software\Microsoft\Inbox\Settings" translation="filesystem">
        <parm name="SMSNoSentMsg" datatype="integer" value="1"/>
        <parm name="ShowRoamWarning" datatype="integer" value="0"/>
        </characteristic>
        <characteristic type="HKCU\Software\Microsoft\Inbox\Settings\OEM" translation="filesystem">
        <parm name="SMSEnableCallback" datatype="integer" value="1"/>
        <parm name="SMSEnablePriority" datatype="integer" value="1"/>
        <parm name="SMSInboxThreadingDisabled" datatype="integer" value="0"/>
        <parm name="SMSCallbackMaxLength" datatype="integer" value="66"/>
        </characteristic>
        <characteristic type="HKCU\Software\Microsoft\SMS\TextShared" translation="filesystem">
        <parm name="IS637MaxAsciiCharacters" datatype="integer" value="160"/>
        </characteristic>
        <characteristic type="HKLM\Software\OEM\SMS" translation="filesystem">
        <parm name="Language" datatype="string" value="100"/>
        </characteristic>
        <characteristic type="HKLM\Drivers\BuiltIn\GSensor" translation="filesystem">
        <parm name="PollingInterval" datatype="integer" value="1000"/>
        </characteristic>
        <characteristic type="HKCU\ControlPanel\BackLight" translation="filesystem">
        <parm name="LightSensorPollingEnable" datatype="integer" value="1"/>
        <parm name="LightSensorInterval" datatype="integer" value="1000"/>
        <parm name="LightSensorThreshold" datatype="integer" value="5"/>
        <parm name="LightSensorToScreenOff" datatype="integer" value="5"/>
        </characteristic>
        <characteristic type="HKLM\Drivers\BuiltIn\RIL" translation="filesystem">
        <parm name="EnableFastDormantDisplayDuringCall" datatype="integer" value="1"/>
        <parm name="DisableSMSWakeUpEvent" datatype="integer" value="1"/>
        </characteristic>
        <characteristic type="HKLM\ControlPanel\Phone" translation="filesystem">
        <parm name="Sleep" datatype="integer" value="1"/>
        </characteristic>
        <characteristic type="HKLM\Software\OEM\TFLOSettings" translation="filesystem">
        <parm name="SpeedHigh" datatype="integer" value="5"/>
        <parm name="SpeedLow" datatype="integer" value="14"/>
        </characteristic>
        <characteristic type="HKLM\System\CWE\Commctrl" translation="filesystem">
        <parm name="UseLongDelayForGestures" datatype="integer" value="1"/>
        </characteristic>
        <characteristic type="HKLM\Software\HTC\SmartTouch\Calendar" translation="filesystem">
        <parm name="ClassName" datatype="string" value="Calendar"/>
        <parm name="WheelCount" datatype="integer" value="2"/>
        <parm name="Mode" datatype="integer" value="4"/>
        </characteristic>
        <characteristic type="HKLM\Software\HTC\SmartTouch\CallHistory" translation="filesystem">
        <parm name="ClassName" datatype="string" value="MSClog"/>
        </characteristic>
        <characteristic type="HKLM\Software\HTC\SmartTouch\Contacts" translation="filesystem">
        <parm name="ClassName" datatype="string" value="MSContactsUI"/>
        </characteristic>
        <characteristic type="HKLM\Software\HTC\SmartTouch\FileExplorer" translation="filesystem">
        <parm name="ClassName" datatype="string" value="FEXPLORE "/>
        </characteristic>
        <characteristic type="HKLM\Software\HTC\SmartTouch\IExplore" translation="filesystem">
        <parm name="ClassName" datatype="string" value="IExplore"/>
        </characteristic>
        <characteristic type="HKLM\Software\HTC\SmartTouch\Programs" translation="filesystem">
        <parm name="ClassName" datatype="string" value="Explore"/>
        </characteristic>
        <characteristic type="HKLM\Software\HTC\SmartTouch\Phone" translation="filesystem">
        <parm name="ClassName" datatype="string" value="Dialog"/>
        </characteristic>
        <characteristic type="HKLM\Software\Microsoft\Today" translation="filesystem">
        <parm name="Date" datatype="integer" value="0"/>
        </characteristic>
        <characteristic type="HKLM\Software\Microsoft\Today\Items\&quot;Ow ner Info&quot;" translation="filesystem">
        <parm name="Enabled" datatype="integer" value="0"/>
        </characteristic>
        <characteristic type="HKLM\Software\Microsoft\Today\Items\&quot;Ta sks&quot;" translation="filesystem">
        </characteristic>
        <characteristic type="HKLM\Software\Microsoft\Today\Items\&quot;Ca lendar&quot;" translation="filesystem">
        </characteristic>
        <characteristic type="HKLM\Software\Microsoft\Today\Items\&quot;De vice Lock&quot;" translation="filesystem">
        </characteristic>
        <characteristic type="HKLM\Software\Microsoft\Today\Items\&quot;Me ssaging&quot;" translation="filesystem">
        </characteristic>
        <characteristic type="HKLM\Software\Microsoft\Today\Items\HTCHomep lug" translation="filesystem">
        </characteristic>
        <characteristic type="HKLM\Software\Microsoft\Today\Items\Windows Live Search" translation="filesystem">
        </characteristic>
        <characteristic type="HKLM\Software\Microsoft\Today\Items\Location Setting" translation="filesystem">
        </characteristic>
        <characteristic type="HKLM\Services\Windows Live\HSAppPlugins" translation="filesystem">
        <parm name="searchURL" datatype="string" value="http://www.google.com/search?q="/>
        </characteristic>
        <characteristic type="HKLM\Software\Microsoft\Welcome" translation="filesystem">
        <parm name="Disable" datatype="integer" value="-19"/>
        </characteristic>
        <characteristic type="HKLM\Software\Microsoft\Clock" translation="filesystem">
        <parm name="GMT_OFFSET" datatype="integer" value="420"/>
        <parm name="AppState" datatype="binary" value="11"/>
        <parm name="TZIndex" datatype="integer" value="53"/>
        <parm name="HomeDST" datatype="integer" value="1"/>
        </characteristic>
        <parm name="NITZEnable" datatype="integer" value="1"/>
        </characteristic>
        <characteristic type="HKCU\CONTROLPANEL\PHONEEXTENDFUNCTION\CDMA" translation="filesystem">
        <parm name="SyncSystemTime" datatype="integer" value="1"/>
        </characteristic>
        <characteristic type="HKLM\SOFTWARE\OEM\PhoneSetting" translation="filesystem">
        <parm name="TrustTimeZoneField" datatype="integer" value="0"/>
        </characteristic>
        <characteristic type="HKCU\Software\Microsoft\Internet Explorer\Main" translation="filesystem">
        <parm name="Search Page" datatype="string" value="http://www.google.com/search?q="/>
        </characteristic>
        <characteristic type="HKCU\Software\Microsoft\Internet Explorer\Main\Default storage location" translation="filesystem">
        <parm name="All Files" datatype="string" value="\Internal Storage"/>
        </characteristic>
        <characteristic type="HKLM\System\OEM_State\RSSI" translation="filesystem">
        <parm name="show_rev_A_icon" datatype="integer" value="1"/>
        </characteristic>
        <characteristic type="HKLM\System\Inbox\Attachments" translation="filesystem">
        <parm name="AttsDir" datatype="string" value="Inbox"/>
        </characteristic>
        <characteristic type="HKLM\Software\Microsoft\Shell\Taskbar" translation="filesystem">
        <parm name="LimitedClock" datatype="integer" value="0"/>
        </characteristic>
        <characteristic type="HKLM\System\Explorer\Shell Folders" translation="filesystem">
        <parm name="My Documents" datatype="string" value="\Internal Storage\My Documents"/>
        </characteristic>
        <characteristic type="HKCR\SystemFileAssociations\Image\Shell\Save \Save Location" translation="filesystem">
        <parm name="" datatype="string" value="\Internal Storage\My Documents\My Pictures"/>
        </characteristic>
        <characteristic type="HKCR\SystemFileAssociations\Audio\Shell\Save \Save Location" translation="filesystem">
        <parm name="" datatype="string" value="\Internal Storage\My Documents\My Music"/>
        </characteristic>
        <characteristic type="HKCR\SystemFileAssociations\Video\Shell\Save \Save Location" translation="filesystem">
        <parm name="" datatype="string" value="\Internal Storage\My Documents\My Videos"/>
        </characteristic>
        <characteristic type="HKCU\Software\Microsoft\Windows\CurrentVersi on\Explorer\Shell Folders" translation="filesystem">
        <parm name="Cache" datatype="string" value="\Internal Storage\Temp\Cache"/>
        <parm name="Cookies" datatype="string" value="\Internal Storage\Temp\Cookies"/>
        <parm name="History" datatype="string" value="\Internal Storage\Temp\History"/>
        </characteristic>
        </characteristic>
        </wap-provisioningdoc>[/code]
        See Post #4 below for grooveROM 4 Versions
        Older grooveROM 5 builds:
        [060509):
        Rapidshare
        Mediafire
        [060409]:
        Rapidshare
        Mediafire
        [060309]:
        Rapidshare
        Mediafire
        [060209]:
        Rapidshare
        Mediafire
        [code]
        **Thanks to Ervirus, DogGuy, Bepe, DCD, no2chem, Cmonex, Juicy, Juggalo X, TobeyChris, Conflipper, ChainFire, MightyMike, ghettofreerider, Calcu, rstoyguy, briggs, OMJ, War Axe, JMZ, Da_G, intx, watzone69, tsowen, da reeseboy, up2no6ood, Cap'nChronic, and many others for making this ROM possible.**
        Special thanks to Calcu for his kitchen which was used to build these roms.
          24MB PagePool
          21232 SYS:
          Modified start menu (4 columns)
          Ultralite - grooveROM 5 wm 6.5 custom theme
          grooveROM 5 - Ultralite wm6.5 phone dialer
          Titanium tweaks and panels added
          Removed OneNote
          Removed Remote Desktop
          Removed Welcome Center
          Removed Customer Feedback
          Included MyPhone
          Included Widgets
          Included Adobe Flash
          Included Marketplace
          Included Office
          Added MSVC 21040
          Included WM 6.5 Ringtones
          Added .net cf 3.5
          OEM App. Name -- Version:
          AdobePDF -- 2_5_1_0_378273_00B
          ArcsoftMMS -- 5_0_82_79R1
          JbedJava_5_1 -- 0_0_20090217_51R2
          LongPressEndKey -- 1_2_19134026_00
          NetworkPlugin -- 1_0_30468_1
          RandomAccess -- 4_1_18222125_0
          TaskManager -- 2_1_37655_1
          SprintDM_GUILib -- 2_0_18174022_0
          Teeter -- 1_4_18201925_0
          RSSHub -- 2_1_1_1083
          Album -- 3_0_19141129_0 VGA
          AudioManager_Eng - 1_6_18221325_0
          FMRadio -- 1_6_18174024_1
          MP3Trimmer -- 1_1_18163629_1
          VoiceRecorder -- 1_10_19123431_0
          YouTube -- 1_6_1822_2028
          HTCUtil -- 4_3_0_0
          InCallRecorder -- 1_0_1821_2426
          AutoRun -- 4_31_6_0
          AutoShortcut -- 1_1_2_0
          BootLauncher -- 1_0_37394_1
          BTBPP -- 1_7_1_R3
          BTFTP -- 1_2_33309_91
          CAMERA -- 6_02_32964_00
          ConcurrenceMgr -- 1_5_1911_1625
          DShow -- 2_00_19131310_0
          FullScreenPlayer -- 1_7_19133625_01
          GSensorCalibrator -- 1_0_18192126_0
          AdvancedPowerManagement -- 1_5_18193426
          HTCApplication -- 1_11_0_0
          HTCGesture -- 1_0_32356_0
          HTCScroll -- 1_0_19113219_0
          LockStreamDRM -- 1_1_081216_O9_05
          mHub -- 6_57_080529_E0
          mHubVO -- 1_71_090227_X0
          PictureEnhancement -- 1_50_19121428_00
          ResourceProxy -- 1_0_19132627_00
          SensorSDK -- 3_3_18192831_1
          SharedModules -- 1_01_19131231_00
          SmartTouch -- 1_0_32417_1
          grooveROM Startup Animation -- 1_1_5_999
          StreamingMedia -- 3_1_19141226_00
          StreamingSrcFilter -- 2_6_19123019_00
          USBtoPC -- 2.2.1911.1625
          acbToggleBT -- 0_8
          Advanced Configuration Tool -- 3_3
          Battery Monitor -- 1_30_0_0
          Flashlite -- 7_0
          Black HTC Calculator -- 1_0_1822_4128
          GfxBoost -- 1_1
          ATContacts -- 0_98
          MusicID -- 1_3_20
          PHM Registry Editor -- 0_70
          Pocket RAR -- 3_8
          psShutXP
          GPS Tool -- 1_2_2_17
          FingerKBD -- 2.1
          Dopewars
          Omnia D3D Driver -- 0_92_0_50
          GSPlayer
          Chess
          Freecell
          Hearts
          Showaco CHome Editor -- 1_6
          Mortscript
          nueGPSSecurity -- 1_2
          Opera -- 9_50_16453 (working Flash)
          HTC Ultralite/grooveROM5 S2A Phone Skin
          PocketVideoPoker -- 0_4_Beta
          groove5HD Black HTC EzInput -- 1_5_32638_1
          reStart
          Sprint Comm Manager
          Black Windows Media Player
          TitaniumWeather v4_2
          Reg Tweaks
          tsowen Custom Taskbar Icons
          Misfortune Battery Meter
          Titanium Notification Panel
          AT Favorite Contacts Panel
          Toggle 1x
          No2Chem's FastCharge
          grooveROM 5 is Sashimi compliant
          All of your cabs, xml files, and more can be autoinstalled on first boot.
          Simply download the attached Sashimi installer, and install to internal storage.
          Then add your .cab files to the \Internal Storage\SASHIMI\Auto\Cab folder,
          and they will be automatically installed on 2nd boot.
          Click here to download Sashimi
          Click here for more info about Sashimi
          This is a Sprint specific ROM.
          (although users of other carriers have reported grooveROM running fine on their devices)
          **Device must be unlocked (click here to unlock).
          I take no responsibility if you mess up your phone.**
          **It is highly recommended to flash to the Stock Sprint ROM before flashing to grooveROM 5.**
          Download grooveROM 5
          Rapidshare
          MyUnspace
          grooveROM 5 - Ultralite Theme:
          The Keyboards:
          Custom Black/Silver grooveROM 5 HTC HD Keyboard:
          (To get the white keyboard skin back, download and install the attached cab below)
          FingerKbd:
          About The Dialers:
          You have two options in Dialers.
          You can use the default Ultralite - grooveROM 5 HTC dialer:
          Or enable the custom Ultralite/grooveROM 5 WM 6.5 dialer
          with the "Disable HTC Phone Skin" cab (start>system tools -- restore with "remove programs"):
          (This will also install BTIconNotifier, so that you can see your BT Taskbar icons without the HTD Dialer)
          If you want to reskin the WM default dialer back to stock or to match your theme, look here:
          http://forum.ppcgeeks.com/showpost.p...postcount=1863
          If you want the Black skin on the HTC S2A Dialer back, look here:
          http://forum.ppcgeeks.com/showpost.p...postcount=1867
          If you want a different grooveROM skinned HTC dialpad, look here:
          http://forum.ppcgeeks.com/showpost.p...postcount=1949
          Please note, the HTC dialer can cause confilcts
          when the 6.5 lock screen is active (including ring delay).
          InCallRecorder only works with the HTC Dialer enabled.
          Pick your poison.
          **Note**
          The wm6.5 S2A only works when device is in lock mode.
          To make device auto-lock when pressing the power button, see here:
          http://forum.xda-developers.com/showthread.php?t=505032
          or here:
          http://forum.ppcgeeks.com/showpost.p...&postcount=709
          Go here for a cab that will restore the start menu to three columns instead of four:
          http://forum.ppcgeeks.com/showpost.p...postcount=1035
          About Opera:
          The built in opera has auto rotation disabled. To enable auto Gsensor rotation in Opera, install the cab in Start>SystemTools.
          Flash is installed and working in this Opera version, however you need to enable plugins in Opera settings.
          About Titanium Plugins:
          Plugins can be disabled, enabled, and moved with CHomeConfig in Start>System Tools.
          About nueGPS Security:
          grooveROM 5 is GPS Security enabled -- for more info look here:
          http://www.nuerom.com/BlogEngine/pos...SSecurity.aspx
          http://www.nuerom.com/BlogEngine/pos...ty-update.aspx
          http://www.nuerom.com/BlogEngine/pos...rity-v112.aspx
          Customizing the Start Menu:
          You can customize the start menu with reStart (settings>system tools)
          ----------------------------------------------------[/code]
          So you want a different Manila version -- or want to install Manila on your wm6.5 grooveROM? Then just flash the Manila Free version in post one, and then install the Manila cab of your choice.
          You can install the grooveROM HD Manila with Flip clock as shown below here.
          Or if you prefer standard Manila, just download and install this Manila Engine cab, and one of Calcu's Manila cabs from his post here:
            updated with newest version.
              Re: [061709] grooveROM 5 - CE OS 5.2.21806 (Build 21806.5.0.5) -- [Diamond
              updated with the newest version.
                Re: [062509] grooveROM 5 - CE OS 5.2.21819 (Build 21820.5.0.4) -- [Diamond
                updated first post with the newest version.
                  Re: [062609] grooveROM 5 - CE OS 5.2.21819 (Build 21820.5.0.40) - [Diamond
                    Re: [062909] grooveROM 5 - CE OS 5.2.23001 (Build 23001.5.0.60) - [Diamond
                    updated first post with newest version
                      Re: [070509] grooveROM 5 - CE OS 5.2.23003 (Build 23003.5.0.60) - [Diamond
                      • Kiit408
                        • Jun 12
                        • 611
                        • HTC P3400i
                        • Vodafone
                        #12
                        Re: [070509] grooveROM 5 - CE OS 5223003 (Build 230035060) - [Diamond
                        lots of updates lol.... well i've been looking for this... bad... lol.... appreciate it... will try next week when i get the diamond next week... thanks....
                        • gogorob
                          • Jun 12
                          • 825
                          • AT@T Tilt
                          • T-Mobile
                          #13
                          good thing im not running this rom i would of been flashing the hell out of my phone..lol but always a good thing updating getting all the bugs and fixes squared away
                          • Kiit408
                            • Jun 12
                            • 611
                            • HTC P3400i
                            • Vodafone
                            #14
                            y do you say that? well about the flashing all the time?...
                              cause groove makes updates rapidly for the rom... he fixes any bug mentiones than releases new version... he doesnt wait to get a few bugs and do them all at once in otehr words.... hes always on top of his roms.
