Requirements: Windows Mobile 2005, 2003SE or 2003 & .NET Compact Framework 2
Overview: Fee up extra space and keep your system at peak performance!
The new MindSoft Pocket Cleaner for Windows Mobile is a powerful memory cleaner for your device. There is no other cleaner in the market as fast and efficient as Pocket Cleaner. It will allow you to erase useless files that occupy space in your device memory and slow it down, while leaving you with less space to keep your files and install new programs. Forget about having to erase files and the hard work of uninstalling applications to install new ones. Keep a big amount of memory in your device, so much, that it will look completely new. IMPORTANT NOTE You need to install .NET Compact Framework 2 to run this application on your device. Please go to
http://www.mindsoftweb.com/pocket/download.htm
grtz cyber weesje
