WM65 - Editor CPR
  • mispook08
    • 3014
    • HTC Vogue (Sprint Touch)
    [RELEASE] WM65 - Editor CPR
    Functional overview
    The screenshot is chinese but the software is in English
    1.Support various types of CPR Editor
    CHome, LockScreen, StartMenu Grid
    2.Text effects editor
    By taking into account the issue of speed editing, text editor as a plug-in effects exist, rather than in a built-in CVE. CVE effect in the simulation simply click, does not mean to see the effects of mobile phones, but in a text editor to see that the effects of mobile phones. At present only one edit, the version will be added behind the magic wand that can directly copy the results to other words.
    3.Folder mapping
    Because a lot of CPR will be directly defined in the document image path, so that picture would have to show CVE Kaodao the Windows directory under the directory, add this version of the path mapping, can be on the local computer can access any map the directory as Windows / Program Files directory. Lane Configuration.xml change in it.
    4.Mapping registry
    With a similar folder, there is a lot of system resources within the registry, ElementMapping.xml mapping can help to solve the problem.
    5.Full custom CPR files
    CPR can edit any of the elements.
    6.Preview mode
    CHome specifically for this model is designed following the design pattern, each of the commencement and CHome state can see, the preview is to check the effect of editing in this mode, CHome hidden template, only those selected item only to start
    7.Code model
    Switch to code mode can view the CPR code. However, CPR is not in favor of changing the code back to reload.
    8.Revoked, redo
    This version in particular an increase of revocation, redo function under the Edit menu, shortcut keys with the same general software: Ctrl + Z, Ctrl + Y
    How to use:
    You need to be replaced CVE Windows directory the following file from your ROM
    This document is a desktop wallpaper, only use this file name. ROM If you are using a jpg file, please change its name into the name above it.
    2.bronzeres.dll
    This file contains the system's own icon CHome, when the registry after import, CVE icon will need to quote CVE extracted the Windows directory in the following name format is "icon ID". Png, when you bronzeres.dll replaced, please delete these icons together, if we do not change, you can not delete, so can I. icon saved some time.
    3.cmhomeres.dll
    The document which contains the system a number of text messages CHome
    4.CVE open, click the file menu to open a CPR, the import process a bit slow, a little patience
    5.Edit menu, click Import Registry .. to the import registry
    6.Enjoy this Tools
    P.S. It just work by .NET 3.5 SP1
    Here is the link to download that
    http://www.microsoft.com/downloads/d...9-81da479ab0d7
    and if your computer's Regional is not in US just tell me where you live
    I'll make a language pak for you
    NOW for
    Original Link:
    http://forum.xda-developers.com/showthread.php?t=524265
    Re: WM65 - Editor CPR
    hi bro nice find this to bad i am not on wm6.5 no more
    grtz cyber weesje
    moderator@spj
