[WM65] [Titanium plugin] TWolf Multiplugin v16C 12/07
  • mispook08
    • 3014
    • HTC Vogue (Sprint Touch)
    Take no credit for this spj
    Multi Settings Editor:
    First I have to thank a couple of ppl, whithout whom this plugin would not see the light of day:
    rPereira, chriscsh, MrDSL and dgaud007 for the great ideas, plugin fixes and CAB optimization.
    APBilbo, for the excelent message to registry app.
    This works on Mortscript (that already comes with Titanium Weather) and takes about 160kb or ram on your device.
    Contents:
    - First page:
    The first page has the skinned clock, small date and the current weather. The weather info and icon is taken from Showaco's Titanium weather. No point on creating a separated weather viewer when that is already perfect. ;)
    If a sms or missed call is received the icons and numbers pop-up on the page.
    The main button opens a pre-chosen link (in my case Resco Explorer, all this is configurable in the Settings), the bottom right button updates the weather (it takes about 10 secs, so be patient).
    If there is a missed call or new message, the main button changes to call history or message app.
    Also, if you have any alarms enabled, it will show a icon, but if you have any unread SMS, the ALARM icon is hidden by the SMS icon.
    - Second page:
    The system bars are on the second page.
    The main button opens Memory settings and the right button open Multi Settings , the left refreshes the plugin, if needed.
    If your memory card is not named "STORAGE CARD", then you must change it on the settings. The battery icon becomes on fire when its being charged.
    - Third page:
    The third page is a SMS viewer, with the help of APBilbo's (Throttle Launcher) Message2Reg.exe.
    Click to see the all the messages, the left softkey to see the previous and the right button to see the next.
    - Fourth page:
    A image viewer is on page 4. You need to configure the folder you want to see on the MultiSettings.
    Click to open the current image, the left softkey to see the previous and the right button to see the next.
    It lists the images on first run (or every time you run the Settings), and it takes some tiem, depending on how many images are there, so be patient.
    Please note that bigger images take longer to load. Also, it loads ALL files, so if you have non-image files in there, it will show a red cross in its behalf.
    - Condensed view:
    The condensed view shows the small weather icon with temperature, the clock (in text view) and the notification icons (if there are any).
    The clock, notifications and battery charge icon auto-updates every 1 second. The rest, every 10 seconds.
    To use:
    - Install Titanium weather (if for some strange reason you havent already and configure your city on it). This also installs Mortscript, that is the base of my plugin.
    - Install this CAB into your device (note that the CPR's will be changed, if it gives you a error during install, use Resco Explorer to remove the read-only property or simply run the attached script-fix made by rPereira.)
    - You can customize some settings if you open the MultiSettings editor (you need Flash 7 to run it).
    - All the icons, clock, bars and shortcuts can be easily skinned and configurable on the instalation folder..
    - Reset and enjoy!
    Whats new on v1.4:
    - Remade the icons, bars and clock skin for bigger sizes (VGA), I only noticed that they looked so bad when I saw a VGA printscrenn... :(
    - Finally changed the network signal icon.
    - Added alarms notifier. The icon is overplaced by the sms icon if you have any unread sms.
    - Added dgaud007 storage card fix, for cards bigger than 2GB (thanks! :D).
    - Added color codes ... This allows for a better use, because it changes the left softkey button by page (all the buttons take about 1 second to update).
    - Theres now a REFRESH left button on system page
    - And a PREVIOUS left button on SMS page, the right button is now NEXT and the main button opens all SMS's.
    - Also a PREVIOUS left button on photos page, the right button is now NEXT and the main button open the picture.
    - Added more shortcuts.
    - Added one shortcut to update the image list, in case you want to see a picture you just took. Since it lists files alphabetically, you probably need to press PREVIOUS to see it.
    - Some code optimization.
    - Was forced to remove the clock background option...too many images. :(
    - Also had to remove the backup battery bar, come to think of it, it wasnt very usefull, since the phone had to be whithout battery for it to show other values than 100%... :D
    - Added operator name to fill in the empty space, only optimized the centering of the text for qvga and wqvga portrait (its the only resolution I have)...
    - Removed older versions from this post and moved the history changes to post #4 (I always forget to create a new thread with 2 or 3 reserved posts :D).
    Some new bugs:
    - This is a new version that changes the way of working of some things and the color codes arent fully tested, so it may contain new bugs.
    - Noticed one small bug that already existed, if you reset your device with notifications pending, their link will become the default even after the notifications disappear. I have to think of a way to fix this, but in the meantime, ppl can use the MultiSettings to fix it manually.
    - Now, because of the color codes, if you jump from this plugin to any other, you have to go thru the clock first, or the left button wont update to your default.
    - Another old bug, if you dont have network signal, the system bar still present 10% for some reason...
    Errors:
    - If for some reason the clock starts to change sizes continuously, go to the second page and use the left softkey button REFRESH.
    - If you have a error opening a shortcut, change it on the MultiSettings that is on the second page right Softkey.
    - If you have a error installing, run the attached rPereira fix first.
    - If the MultiSettings editor doesnt close properly, you need to install Flash 7,
    - If the weather icons is not appearing, update your Titanium weather with this small fix: http://forum.xda-developers.com/show...postcount=1077
    - If the left button doesnt change for some reason... Post here a PNG screenshot with the correct size of your today screen. If you dont know how to do this, install mymobiler.com and post here a screenshot of your screen, make sure the size is correct. Since this forum transforms the PNGs in JPGs youll need to host it outside, for example, you can host your image on imageshack.us .
    Whats new on v1.5:
    - Fixed the 12-hour clock bug
    - Added fix to automaticly change back to the default left button if you changed plugin without passing by the clock page.
    - Fixed the AM-PM bug, thanks Gibbs.
    - Added different OS languages install support.
    - Updated the Multi Settings Editor to support this too.
    - Removed update from first post.
    - v1.4 history moved to post #4.
    Errors:
    - If the clock starts to change size continuously, go to the second page and use the left softkey button REFRESH.
    - If the weather icon is giving an error, update your Titanium weather with this small fix:
    - If your clock is a 12 hour clock, you need to add the attached update after install.
    - If your weather icons have a wierd size, I'd advice the Beyond Invisible Iconset.
    - If you reset your device with notifications pending, that link becomes the default, even after the notifications disappear. I have to think of a way to fix this, but in the meantime, ppl can use the Titanizer to fix it manually.
    To Do:
    - Add WVGA and QWVGA landscape screen sizes (users, please help)...
    - Fix bug that never shows phone signal as 0% even if its off.
    - Fix bug that doesnt close M2RW.EXE (used by Message2REG) from the system, stealing over 600kb of ram.
    - After receiving a new SMS the Message2REG should update the sms list.
    - Add option to enable/disable this plugin as default clock (if its possible).
    Small update v1.5b:
    - Fixed bug that never showed phone signal as 0% even if it was off.
    - Fixed bug that didnt closed M2RW.EXE from the system, stealing over 600kb of ram.
    - After receiving a new SMS now the Message2REG updates the SMS list every 10 seconds.
    - Fixed small bug on the Settings that didnt restored the correct values (on non-WWE systems).
    - To install, copy the attached files to the TWolf instalation folder and reset or use the Restart_TWolf script.
    TWolf Multiplugin v1.5b (+ new beta 1.6) [/SIZE][/CENTER][/COLOR]
    I'm attaching the latest beta here only, I'm not going to add it in the main post because if I cant get the menus bigger or make the set wallpaper work on all images, Ill have to go in another direction.
    What's new:
    - The main button on the picture page open a menu.
    - The main button on the sms page open a menu.
    - Reply to sms on the menu
    - New sms on the menu (not on this screenshot)
    - Refresh list on the menu
    - Add as wallapper on the menu (restricted to jpg with your screen size)
    - Different refresh mode
    - Changed the network signal check
    - Removed the refresh list from TWolf.mscr.
    - Added a "are you sure?" dialog to the refresh list
    [WM6.5] [Titanium plugin] TWolf Multiplugin v1.6 (New menus, more options)
    v1.6:
    What's new in v1.6:
    - The main button on the picture page opens kvvQuickMenu.
    - The main button on the sms page also opens a menu.
    - Add as wallpaper on the menu (restricted to jpg images with your screen size)
    - Removed the refresh list from TWolf.mscr, its now manual (less time on boot).
    - Removed some unnecessary files from the CAB.
    - v1.5 moved to post #4.
    What's new in v1.6c
    - Fixed small bug that didnt open the main image. A manual fix is also here:
    http://forum.xda-developers.com/show...&postcount=395
    - Removed the other buggy versions
    Re: [WM65] [Titanium plugin] TWolf Multiplugin v14 (BETA)
    Hi bro i dont see 1.40 in the attachments and now changelog
    EDIT DONE UPDATED THREAD WHIT CHANGELOG AND FILES
    grtz cyber weesje
    moderator@spj[/QUOTE]
    • GokuSS3
      • Jun 02
      • 2247
      • HtC ToUcH PrIzZo 2
      • T-Mobile
      Gonna give this a try an post back for everyone.
      If I Have Helped Be Sure To Hit That Thanks Button!!!
        Re: [WM65] [Titanium plugin] TWolf Multiplugin v15
        bump bump new releas changelog addet to the first posted hit thanks
        grtz cyber weesje
        moderator@spj
          Re: [WM65] [Titanium plugin] TWolf Multiplugin v15B 20/06
          bump bump new update addet to the first posted
          MODERATOR@SPJ
          • mispook08
            • 3014
            [WM6.5] [Titanium plugin] TWolf Multiplugin v1.5b (+ new beta 1.6)
            What's new:
              Originally posted by jr5416
              [wm6.5] [titanium plugin] twolf multiplugin v1.5b (+ new beta 1.6)
              i'm attaching the latest beta here only, i'm not going to add it in the main post because if i cant get the menus bigger or make the set wallpaper work on all images, ill have to go in another direction.
              What's new:
              what's new:
              - the main button on the picture page open a menu.
              - the main button on the sms page open a menu.
              - reply to sms on the menu
              - new sms on the menu (not on this screenshot)
              - refresh list on the menu
              - add as wallapper on the menu (restricted to jpg with your screen size)
              - different refresh mode
              - changed the network signal check
              - removed the refresh list from twolf.mscr.
              - added a "are you sure?" dialog to the refresh list
              grtz cyber weesje
              moderator@spj
              • mispook08
                • 3014
                v1.6:
                What's new in v1.6:
                  What's new in v1.6:
                  - v1.5 moved to post #4.[/QUOTE]
                  he bro update the first posted
                  MODERATOR@SPJ
                    Re: [WM65] [Titanium plugin] TWolf Multiplugin v16C 09/07
                    bump bump new releas addet
                    grtz cyber weesje
                    moderator@spj
