G-Trigger v091 beta 11/07/09
    [UPDATES] G-Trigger v091 beta 11/07/09
    G-Trigger is a G-Sensor based ^shake^ detector application for Windows Mobile. It allows to trigger a predefined action on shaking your mobile phone in particular direction.
    Supported shaking directions:
    Horizontally
    Left to right
    Right to left
    Vertically
    Top to bottom
    Bottom to top
    Front & Back
    Front to back
    Back to front p
    It is developed for HTC Touch Diamond
    More info
    http://g-trigger.kneps.com/
    G-Trigger v0.8.0 beta [14-Jun-2009]
    * Added: Different actions for shaking device when FaceDown and shaking device when FaceUp
    * Added: New user interface for organizing profiles with ease
    * Added: Auto-trigger profile option “Manila music is playing
    * Added: Import/Export settings and/or profiles
    * Fixed: Samsung Omnia G-Sensor code to sort out issue of service crash after device is awake
    * Fixed: Auto-resize configuration utility dependent on resolution
    * Fixed: Faster editing of shake actions after opening edit profile once
    * Fixed: Modification to profile actions no more required to hit save button to make it active
    * Updated: Slight modification to shake algorithm to make front-back action more sensitive
    * Updated: new registry location ‘HKCU\Software\Kneps\G-Trigger’ (you will require to delete older location ‘HKCU\Software\G-Trigger’ manually.....).
    G-Trigger v0.9.1 beta [10-Jul-2009]
    By Krupal Desai
    Video: See it in action...
    G-Trigger is a G-Sensor based ^shake^ detector application. It allows to trigger a predefined action on shaking your mobile phone (built-in with G-Sensor) in particular direction. Currently it is in development phase, so please bare the bugs.
    Horizontally
    Left to right
    Right to left
    Vertically
    Top to bottom
    Bottom to top
    Front & Back
    Front to back
    Back to front
    It will trigger the specified action when phone is forcibly moved from left to right or moved as above mentioned directions. Also you can assign different actions with keeping device face up and shaking device in any of the above action or keeping device face down and shaking device in any of the above action.
    Currently supported actions:
    Close/Minimize active window
    Dial a number
    Answer/Reject incoming call
    Launch Program
    Ringer Loud/Vibrate/Silent
    Screen orientation
    Send Keys*
    Task Switch
    Turn On/Off screen
    WiFi/Bluetooth/Phone radio - On/Off/Toggle
    Media Controls#
    Volume Control
    Simulate Power Button - Power Off/Power On/Long Press Power Button
    Open control panel settings
    Activate profile
    Save Screenshot (BMP/JPG/PNG/GIF at predefined location) *new
    Change Wallpaper (Today Screen, Manila Home & S2U2) *new
    Show/Hide/Toggle On-Screen Keyboard (SIP) *new
    *Please refer to readme.txt for sending special keys.
    #Currently supported media players are: Windows Media Player, S2P, Microfi Nitrogen, Core Player, TCPMP, Pocket Player, Pocket Music and Manila (TF3D) Music Tab.
    G-TriggerService will be suspended till the program specified in exceptions list is active.
    Known Facts:
    OSD is displayed with some delay after event is occurred
    Sometimes shake actions are not triggered when device is busy processing
    Action Media Control "Stop" does not work for all players
    Media controls for "Pocket Player" works till it's window is active or minimized (not working when in notification mode)
    Further development:
    Display configured actions as OSD when device is lightly shaked
    Add more actions like "Navigate Manila Page", "Open Quick Launch" etc on shaking
    It is developed for HTC Touch Diamond. I have not tested it on any other device. Let me know if you try it on other device.
    NOTE: Although running this application does not seem to make any damage, I take no responsibility for any kind of damage caused to the device or data due to this application.
    PS: Credits to Koushik Dutta for sharing G-Sensor managed code for Diamond. Many thanks to Ageye for sharing updated G-Sensor code for Samsung Omnia (here).
    Usage:
    Transfer .cab file to any location in device.
    Run the .cab file and install application to device storage.
    Run the “G-Trigger” shortcut from programs.
    Click “New” button on “Action” tab.
    Enable the check boxes for the actions you want to activate.
    Assign any action by clicking “…” button on the right side of action text box.
    Click “Save” button on edit profile page, again click “Save” button on main page.
    Click “Start” button to start the service.
    Shake your phone and enjoy!
    Fixed: Null reference bug on fresh installation
    G-Trigger v0.9.0 beta [02-Jul-2009]
    Added: Actions
    Added: Added option to enable/disable debug logs
    Added: Lower threshold value up to 5 for front-back actions
    Added: Profile priority setting for auto-trigger profile option
    Added: Included new samsung SDK for G-Sensor in setup
    Fixed: Unable to detect screen is off on certain devices
    Fixed: Auto Start Service on device boot up issue (introduced in 0.8.0)
    Fixed: Few minor bugs
    grtz cyber weesje
    Re: G-Trigger v091 beta 11/07/09
    bump bump new releas addet
    grtz cyber weesje
    moderator@spj
