Pointui True Glass v03[QVGA/WQVGA]
  • mispook08
    • 3014
    • HTC Vogue (Sprint Touch)
    [Theme] Pointui True Glass v03[QVGA/WQVGA]
    V 0.3: Added GlassClock, now you don't need to overwrite the original HomeClock, just Unzip the GlassClock folder and copy it under the AppletRibbon folder, launch it from applets panel under PointUI. Minor changes on the theme (applet panel icon, theme icon).
    Added the GlassClock 12H mod, you just need to replace the original GlassClock.cs inside the applet folder with the 12H modded one.
    V 0.2: Modified home screen title background. Added notification icon.
    VGA removed, I'm not willing to mess anymore on trial and error trying to convert my themes. Sorry.
    19/03/09 UPDATE : Added the search button on the homepage, as requested, if you don't like it and you want to remove the bar look here
    Added the Alarm.Off.jif in homeclock skin. VGA version is a pain in the a$$ because i cant test it every time I repack the images, so please leave feedback.
    UPDATE: Modified the graphics a little after .28 release, removed fake transparency which caused some troubles on square resolution devices. Done a VGA version which is to test because i've just scaled up the images.
    Hi all,
    this is my new theme "True Glass", as you see it's a pretty transparent and neutral them which works better on low contrast and monocromatic backgrounds like, well, gradients :D, but obviously feel free to experient.
    I've added a skin for 2 apps i usually use, World and Homeclock (thanks to ibrythill or his work).
    The theme doesn't work well on landscape.
    Original Link;
    http://community.pointui.com/topic/theme-true-glass
