I did not write this app and take no credit for it.
This app allows you to change the ringtone, notification, and alert sounds on one page. It does not have a "revert to default" option so you need to manually add the stock sounds to you pre if you want to get them back after changing them. Here you can download the original alert and notification sounds.
"Be Advised. When the notification is triggered, it will play the entire sound and you can not stop it short. If you pick a 20 minute Phish & DMB Jam Session for your notification sound it will play all of it!"
Instructions:
You need to email the link below to yourself in the body of the email and open the link from your email on the Pre. The phone will freeze for a bit but when its alive again you will see the icon on your first program page.
Source:
Instructions:
http://forums.precentral.net/spe_attachment/download-20442-org.webosinternals.kaerey.app.mynotification.ipk
Source:
http://forums.precentral.net/1709226-post1.html
