Titanium theme Bufed VGA
    [RELEASE] Titanium theme Bufed VGA
    Thanks for esbow over at XDA for this theme
    [Beta-2 VGA-QVGA 0.30.11]update 4 July 2009
    *added support for landscape on VGA
    [BETA-1 w-VGA/w-QVGA 0.30.10f PORTAIT]update 3 July 2009
    I don't own an VGA device so its all touch an go on the layout,
    but it seems to come out well. thanks for the pm's
    *added support for VGA portrait( test. landscape after the test)
    *added more pluggin support( COpera, CFacebook, CHTC AudioManager)
    *added bigger layout for QVGA( test)
    *added effect to QVGA landscape mode( experimental)
    *updated pluggin support
    *varia fixes
    Updates:
    landscapeTest -Titanium Bufed 0.20.04.QVGA.WQVGA update 30 June 2009
    (proper upgrade version)
    *added landscape for QVGA WQVGA
    *Adjusted landscape mode( v2)
    **Clock, music, picture layout ect..
    *Fixed some flow problem
    *added better support for CClauncher( still no icon:/)
    *added support for Quicklauncher( + icon)
    *added better support for CS2P
    *fixed some CComm bugs( still no icon:/)
    *fixed date display problem
    Titanium Bufed 0.20.03b update 29 June 2009
    ( Don't forget to set clearview on)
    *Fixed some font problems
    *fixed layout
    *added support for WQVGA
    *added support for CVolume
    *added some missing files for reflection
    *fixed some minor setting
    *fixed font setting
    *fixed TWolf plugin 1.5 for Bufed( below)
    *Background art is not included.( QVGA) (VGA)
    Updates:
    Titanium Bufed 0.12b1.0609.cab Updated 24 June 2009
    | TWolf and Showaco plugins |
    *added support for Favorite People Plugin by AppStar
    *added support for Titanium Weather by showaco
    *added support for cS2P v0.2 - S2P music player control: ( Bufed 0.1 plugin below)
    *minor bugs( weather icon not displaying..)
    *minor graphical updates
    *disabled picture name till next update
    Titanium Bufed 0.12.0609.cab Updated 4 June 2009
    *updated big album art
    *updated big picture art
    *new clock layout
    *fixed clock displey bug on some devices( hopefully..)
    *updated icons
    *updated some minor fixes
    Titanium Bufed 0.02.0609 - initial release
    *new Bufed icon set
    *larger album art
    *larger picture art
    *new clock
    Bugs found:
    - at CET zero hour( 00:00) the time doesn't fully display - will be fixed on next update( FOU)
    - battery status doesn't display correct status on some devices- FOU *fixed
    - some other plugin's "may" disappear depending on your config. Just reinstall them and refresh Titanium..
    - most plugin's work but "may" need some tweaking, I will add more support as we go along ( FOU)
    [ its all an mater of of the installation follow order:
    skin, weather, weather CPR fix, TWolf's. If it fails, try again. It works, and its just a one time procedure. Best to reboot the device after an installation..]
    | Titanium Bufed Extras 0.11.0609: adds extra Bufed system icons to Titanium. Recommended.
    | albumart fix 0.2: adds extra shadow under the album art background. Just install the cab file. 24 June 2009
    | Showaco Bufed weather icons: just install the cab file and go to Weather Options, Display Options, select Bufed..
    | TWolf Plugin - Bufed 0.02 : added Bufed system icons and new flip-clock. 24 June 2009 (Complete Patched plugin here)
    Original Link:
    http://forum.xda-developers.com/showthread.php?t=528935
  • mispook08
    • 3014
    • HTC Vogue (Sprint Touch)
    Re: Titanium theme Bufed VGA
    Thanks bro now youll get your rep you deserve and we got a brand new VGA theme .
      can someone attach pictures... at work and cant see em.
        he bro done addet as attachment
        MODERATOR@SPJ
          MODERATOR@SPJ
          thanks for attaching the pics and a very nice looking theme :) background would have to be changed though for my tastes.
