**Thanks to Ervirus, DogGuy, Bepe, DCD, no2chem, Cmonex, Juicy, Juggalo X, TobeyChris, Conflipper, ChainFire, MightyMike, ghettofreerider, Calcu, rstoyguy, briggs, OMJ, War Axe, JMZ, Merdinh, Da_G, intx, watzone69, tsowen, da reeseboy, up2no6ood, Cap'nChronic, and many others for making this ROM possible.**
Special thanks to Calcu for his kitchen which was used to build these roms.
grooveROM 5 is Sashimi compliant
All of your cabs, xml files, and more can be autoinstalled on first boot.
Simply download the attached Sashimi installer, and install to internal storage.
Then add your .cab files to the \Internal Storage\SASHIMI\Auto\Cab folder,
and they will be automatically installed on 2nd boot.
Click here to download Sashimi
Click here for more info about Sashimi
This is a Sprint specific ROM.
(although users of other carriers have reported grooveROM running fine on their devices)
**Device must be unlocked (click here to unlock).
I take no responsibility if you mess up your phone.**
**It is highly recommended to flash to the Stock Sprint ROM before flashing to grooveROM 5.**
Click here
to download
grooveROM 5
**There is a known issue with this build -- device appears
to freeze at WM welcomehead on first boot.
It's not frozen, just tap the screen to start. **
grooveROM 5 - Ultralite Theme:
The Keyboards:
grooveROM custom black SIP:
FingerKbd:
About The Dialers:
You have two options in Dialers.
You can use the default HTC stock dialer with custom grooveROM 5 skin:
Or enable the custom Ultralite/grooveROM 5 WM 6.5 dialer
with the "Disable HTC Phone Skin" cab (start>system tools -- restore with "remove programs"):
(This will also install BTIconNotifier, so that you can see your BT Taskbar icons without the HTD Dialer)
If you want the Black skin on the HTC S2A Dialer back, look here:
http://forum.ppcgeeks.com/showpost.p...postcount=1867
If you want a different grooveROM skinned HTC dialpad, look here:
http://forum.ppcgeeks.com/showpost.p...postcount=1949
If you want to reskin the WM default dialer back to stock or to match your theme, look here:
http://forum.ppcgeeks.com/showpost.p...postcount=1863
Please note, the HTC dialer may cause confilcts
when the 6.5 lock screen is active (including ring delay).
**Note**
The wm6.5 S2A only works when device is in lock mode.
To make device auto-lock when pressing the power button, see here:
http://forum.xda-developers.com/showthread.php?t=386451
Go here for a cab that will restore the start menu to three columns instead of four:
http://forum.ppcgeeks.com/showpost.p...postcount=1035
About Opera:
The built in opera has auto rotation disabled. To enable auto Gsensor rotation in Opera, install the cab in Start>SystemTools.
Flash is installed and working in this Opera version, however you need to enable plugins in Opera settings.
About Titanium Plugins:
Plugins can be disabled, enabled, and moved with CHomeConfig in Start>System Tools.
Customizing the Start Menu:
You can customize the start menu with reStart (settings>system tools)
[/B]
[FONT=Arial Black][COLOR=White] [B]24MB PagePool XIP patched with nueSpinLock [B]21932 SYS:[/B] Modified start menu (4 columns) Ultralite - grooveROM 5 wm 6.5 custom theme grooveROM 5 - Ultralite wm6.5 phone dialer Titanium tweaks and panels added Removed OneNote Removed Remote Desktop Removed Welcome Center Removed Customer Feedback Included MyPhone Included Widgets Included Marketplace Included Office Included WM 6.5 Ringtones Added .net cf 3.5 [B] OEM App. Name -- Version:[/B] [/COLOR][/FONT] [LEFT][FONT=Arial Black][COLOR=White]AdobePDF -- 2_5_1_0_378273_00B[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] ArcsoftMMS -- 5_0_82_79R1[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] JbedJava_5_1 -- 0_0_20090217_51R2[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] LongPressEndKey -- 1_2_19134026_00[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] NetworkPlugin -- 1_0_30468_1[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] RandomAccess -- 4_1_18222125_0[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] TaskManager -- 2_1_37655_1[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] SprintDM_GUILib -- 2_0_18174022_0[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] Teeter -- 1_4_18201925_0[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] RSSHub -- 2_1_1_1083[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] Album -- 3_0_19141129_0 VGA[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] AudioManager_Eng - 1_6_18221325_0[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] FMRadio -- 1_6_18174024_1[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] MP3Trimmer -- 1_1_18163629_1[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] VoiceRecorder -- 1_10_19123431_0[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] YouTube -- 1_6_19161426_00[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] HTCUtil -- 4_3_0_0[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] AutoRun -- 4_31_6_0[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] AutoShortcut -- 1_1_2_0[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] BootLauncher -- 1_0_37394_1[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] BTBPP -- 1_7_1_R3[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] BTFTP -- 1_2_33309_91[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] CAMERA -- 6_02_32964_00[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] ConcurrenceMgr -- 1.2.1819.2826.0000[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] DShow -- 2.00.1914.3426.0[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] FullScreenPlayer -- 1_7_19133625_01[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] GSensorCalibrator -- 1.0.1821.2730.0[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] AdvancedPowerManagement -- 1_5_18193426[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] HTCApplication -- 1_11_0_0[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] HTCGesture -- 1_0_32356_0[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] HTCScroll -- 1_0_19113219_0[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] HTC Application -- 1.13.0.1[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] LockStreamDRM -- DRM 1.1.081216.O9.08[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] mHub -- mHub VO 1.75.090515.X0[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] mHubVO -- 1_71_090227_X0[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] PictureEnhancement -- 1_50_19121428_00[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] ResourceProxy -- 1.0.1915.1630[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] SensorSDK -- 3_3_18192831_1[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] SharedModules -- 1.01.1914.2727.00[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] SmartTouch -- 1_0_32417_1[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] grooveROM Startup Animation -- 1_1_5_999[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] StreamingMedia -- 3_1_19141226_00[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] StreamingSrcFilter -- 2_6_19123019_00[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] USBtoPC -- 2.2.1912.2329.0[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] acbToggleBT -- 0_8[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] Advanced Configuration Tool -- 3_3[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] Volume Control -- 1_6_1820_1829[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] Battery Monitor -- 1_30_0_0[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] Flashlite -- 7_0[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] Black HTC Calculator -- 1_0_1822_4128[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] GfxBoost -- 1_1[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] ATContacts -- 0_98[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] PHM Registry Editor -- 0_70[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] Pocket RAR -- 3_8[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] psShutXP[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] GPS Tool -- 1_2_2_17[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] FingerKBD -- 2.1[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] Dopewars[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] GSPlayer[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] Chess[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] Freecell[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] Hearts[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] Showaco CHome Editor -- 1_6[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] Mortscript[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] Opera -- 9_50_15613 (working Flash)[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] Tachi Dialer with custom grooveROM skin[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] PocketVideoPoker -- 0_4_Beta[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] Merdinh Black HTC EzInput -- 1_1[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] reStart[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] Sprint Comm Manager[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] Black Windows Media Player[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] TitaniumWeather v4_2[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] Reg Tweaks[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] Titanium Notification Panel[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] AT Favorite Contacts Panel[/COLOR][/FONT] [FONT=Arial Black][COLOR=White] Toggle 1x[/COLOR][/FONT] [FONT=Arial Black][COLOR=White]No2Chem's FastCharge OutlookEnhancement_1_1_1822_3121 MessageEnhancement_1_0_19142725_01 [/COLOR][/FONT][/LEFT]
Click here
to download
grooveROM 5
The Keyboards:
FingerKbd:
About The Dialers:
**Note**
About Opera:
