Numpty Physics v10
  • GokuSS3
    • Jun 02
    • 2247
    • HtC ToUcH PrIzZo 2
    • T-Mobile
    [RELEASE] Numpty Physics v10
    Numpty Physics v1.0 (Freeware)
    Requirements: PocketPC 2003(SE), WM5, WM6
    Overview: Numpty Physics is a physics game for Windows Mobile phones.
    Numpty Physics is a physics game for Windows Mobile phones. The purpose of the game is to get the red ball towards the yellow star. You can use the stylus to create new objects that you can fling around using the game’s built-in physics engine.
    UP previous level
    DOWN Next level
    RIGHT restart animation
    LEFT seems to exit the game
    centre button nothing happens
    Reported working on:
    Dell Axim X51v / VGA / WM5
    iPaq HX2790 / QVGA / WM5
    Microsoft device Emulator on Windows XP / QVGA / WM5
    HP211 / VGA / WM6
    HTC TyTn II (Kaiser) (the DIAMOND cab)
    http://www.freewarepocketpc.net/ppc-download-numpty-physics.html
    http://www.megaupload.com/?d=I1ZQ28JU
    Mirror:
    http://rapidshare.com/files/252673111/Numpty_Physics.cab
    < CAB file: Numpty_Physics.cab - No serial needed
    If I Have Helped Be Sure To Hit That Thanks Button!!!
  • DirtySocks
    • May 24
    • 27
    • HTC 6800
    Re: Numpty Physics v10
    Doesn't work on WM. I get a message saying that it is not a valid WM apps.
      its been tested to work... are you running 6.5 cause that may be the problem. been tested to work ansd look at the descripton.... says it works without trooubles and was made for windows.
      • Sh0wNuF
        • Jul 09
        • 439
        • Sprint Touch Pro
        it works just fine on my touch pro...it has worked on both mighty 5 and sss 203 so it might just be your rom....BTW this game is sweet in its simplicity...I love it, just wish there were more levels
          are you running a stock rom? been tested to work on the pro now...
          • OgReNaToR
            Member
            • Aug 22
            • 63
            • HTC Tilt
            • AT&T
            so.....its this touchscreen? from the description it seems like it doesnt support touchscreen
            wow never mind im an idiot....it says use the stylus....epic FAIL!!
              HI MAYBEY READ AGAIN You can use the stylus to create new objects that you can fling around using the game’s built-in physics engine.
              MODERATOR@SPJ
              • OgReNaToR
                Member
                • Aug 22
                • 63
                • HTC Tilt
                • AT&T
                it no worky on WinMo 6.5 :(
                  Originally posted by ogrenator
                  it no worky on winmo 6.5 :(
                  yeah can be have you try the wm6.5 game fix attach below
                  grtz cyber weesje
                  moderator@spj
                  • OgReNaToR
                    Member
                    • Aug 22
                    • 63
                    • HTC Tilt
                    • AT&T
                    ill give it a shot and let you guys know...
                    --------- New Post Merged on 31/7/2009 at 1128 --------
                    still no worky for me...the cab helped out a ton with other games tho...even ones that never used to work under 6.1 but this game is still a no go on WinMo 6.5 for me...hope someone else has better luck...
