Silent Spy v1.0[/b] (Freeware)
Requirements: PPC WM5, WM6
Overview: Let this lightweight application inform you , if someone changes your sim card in case of theft. This application will inform you through sms the new number using your device. Done to be simple!
You, as the owner of your phone, register your SIM card as the only valid one. You decide that a friend or a relative should receive a message in case that your phone has been lost or stolen. That is your alert number! One day, you lose your phone device. You try to call your own number and you realize that your SIM is not active anymore. That's probably because someone swapped the SIM card. At the same moment, after inserting a new SIM card, the software sends out an sms to your registered alert number. The software will repeat the same procedure whenever Windows starts up. Silent Spy works all in the background, therefore the user doesn't receive any alerts or messages of what is going on. Since you have the new number which is using your device, it's up you to contact him/her and try to get it back.
Description: Silent Spy is a freeware for Windows Mobile that helps people finding their lost or stolen phones. The software was tested sucessfuly in some devices, however it is still in its beta version, before i can reach as many users as possible to give me feedbacks about possible bugs.
How it works: Silent Spy monitors your phone SIM card, authenticating it with a registered one. If this authentication fails, a sms message is sent to an alert number, informing that a new SIM card has been inserted in your phone.
An example of usage: You, as the owner of your phone, register your SIM card as the only valid one. You decide that a friend or a relative should receive a message in case that your phone has been lost or stolen. That is your alert number! One day, you lose your phone device. You try to call your own number and you realize that your SIM is not active anymore. That's probably because someone swapped the SIM card. At the same moment, after inserting a new SIM card, the software sends out an sms to your registered alert number. The software will repeat the same procedure whenever Windows starts up. Silent Spy works all in the background, therefore the user doesn't receive any alerts or messages of what is going on. Since you have the new number which is using your device, it's up you to contact him/her and try to get it back.
Silent Spy for PPC v1.0
Perfom a "soft reset" on your device after installing it, otherwise the application will fail. The best known way to perfom a soft reset, is inserting your stylus pen inside inside the hole located in you phone device.
Password for first log in: "123456".
More Info: Install the cab, execute the application and log in with the following password: "123456" (change it after using it. Follow the instructions and change your information and application preferences.
[DOWNLOAD]http://www.megaupload.com/?d=FPA1NDX3[/DOWNLOAD]
http://www.codexistence.com/projects.php?id=1
