• Requirements:
Pocket PC 2002, Windows Mobile 2003, 2003 SE, and 5.0
v1.01
ArithmeTick is challenging math game where you solve addition, subtraction, multiplication and division problems!
How fast can you add and multiply? Solve math problem against the clock to achieve the highest score! A practice mode is also included to help sharpen your math skills.
With four difficulty levels, ArithmeTick is challenging for kids and adults!
The objective in ArithmeTick is to solve as many addition, subtration, multiplication, and division problems as possible before time runs out.
You are awarded up to 10 points for each correct answer depending on how quickly you can solve the math problem. You are also awarded extra time for each problem you solve correctly.
Challenge problems occur at the end of each level and are awarded 50 points for a correct answer. You can skip the challenge problem by clicking the skip button.
Tip: If you enter a wrong number by mistake you can clear your current guess by clicking on the problem.
