SVMPowerMgr v1.0 (Freeware)
Requirements: PPC WM6
Overview: With SVMPowerMgr, you can: turn off the screen, put the device in suspend mode, soft reset and power down.
May be "power manager" sounds hard, this app. do exactly the same as per example psShotXP, namely:
- Turn off the screen of Your device.
- Put the device in suspended mode.
- Soft reset the device.
- Turn off the device.
You also can create 4 shortcuts to the program with parameters:
- 0: turn off the screen of Your device.
- 1: put the device in suspended mode.
- 2: soft reset the device.
- 3: turn off the device.
In the attached archive is a folder with those shortcuts, as the cab installer does not make them, only one shortcut of main program in the "Programs" of the device.
About "turn off". I've tested these only on my Touch HD, and I've used the functionality of this device: PowerOffWarning (when you long-press the power button). May be this will work on Diamond too, I do not have them...
You can change the images of backrounds and buttons, they will be located in "Images" folder after install. With one restriction: now the buttons are black, so if you change the back of main program, consider this...
< CAB file:
http://forum.xda-developers.com/showthread.php?t=537680
http://www.megaupload.com/?d=8CWAGJU1
[url=http://rapidshare.com/files/257443419/SVMPowerMgr.CAB][b]SVMPowerMgr.CAB[/b][/url] - [color=green]No serial needed[/color
