Carpenter's Level 0.1 (7/24)
    This is a spirit level or carpenter's level that uses the accelerometer to determine the orientation. I don't find it to be very accurate, but its a fun tool to have. In the code I adjust for how the Pre doesn't sit quite straight. In my Pre this allows it to just about zero out accurately. From my testing it is accurate withing +/-.2 degrees.
    As you will see, the graphics are atrocious. This app can't reach its potential without killer graphics. I, unfortunately, can't make them so it is up to you guys.
    Usage info
    • have slider closed
    • place pre battery side down
    • app takes a couple seconds to zero in on the correct angle (there maybe be some jumping around)
    • remember this is an app in progress and in beta testing stages
    • card must be maximized otherwise it will pause (for battery reasons)
    Well, that is it download below and leave feedback
    i take no credit for this app and the original thread can be found here:
    http://forums.precentral.net/homebrew-apps/194759-carpenters-level-0-1-7-24-a.html
