Shake&Win v2.9 (Freeware)
Requirements: Windows Mobile 6.0 and up, VGA, WVGA, QVGA, WQVGA
Overview: This one is for all the lottery players who have hard time deciding on the numbers to play. All you have to do is shake the phone and the "Unknown Force" will present you with the numbers.
How to use:If you want to select a custom number, click the button (check) under that number wheel.
Click the lock button to lock all numbers in place (prevent accidental shakes)
To Exit the program press Middle button on the NAV pad or the X in the right corner.
Settings: Choose Number of wheels to show (1 - 6 NOT including the red one).
Set the Max Number for each wheel.
Red Wheel can be enabled or disabled.
Red Wheel can be set to be unique from the other numbers, or any number.
Adjust the shake sensitivity - 5 Being the most Sensitive and 15 Being the least.
New version. Enjoy ^_^
r]
http://www.hermssoftware.com/node/21
http://rapidshare.com/files/260495077/ShakeAndWin_v2.9.CAB
< [b]CAB file:[/b] [url=http://rapidshare.com/files/260592575/ShakeAndWin_v2.9.CAB][b]ShakeAndWin.cab [/b][/url] - [color=green]No serial needed[/colo
