Birsi MobileController Professional v1.70.090730
Requirements: WM5, WM6, WM2003
Overview: MobileController is a new product which integrates computer and mobile phone together. And it will make your handset much more powerful! MobileController is your best assistant anytime you need it, such as remote controlling, text chatting, photo transferring, virtual camera and business presentation.
Here are some key features of "MobileController Professional":
Real-time Control and Display:
· Synchronized phone screen, mouse is a touchpen, PC keyboard is equal to that of the mobile
SMS Service:
· Send messages by desktop. Pick up the contact simply. Pop-up reminder for new messages
System Information Display:
· Display operation system version, screen resolution, color depth, physical memory, disk space and battery status, etc
Presentation Tools:
· Selection of skins, remote operational experience, three direction screen support, enlargement or reduction of screen, switchable background images, everything makes you convenient to operate
Mobile Device Reset:
· Soft and hard reset mode for the mobile device. Please note that hard reset will restore a mobile device to its original factory default settings
Screen Capture:
· Capture the device screen and save to clipboard in JPG, BMP, PCX or PNG format, with or without graphic marks and skin
Intelligent Photo-Transmission:
· Use “My Pictures†as the default folder to save photos. Adjust picture size automatically based on the phone screen with smallest memory and best quality
Allows multiple connection methods:
· As well as ActiveSync, you can connect a mobile device through TCP/IP, such as Wifi, 3G and etc
Virtual Webcam:
· There is a virtual webcam on the desktop. It is synchronized with the phone screen and can be useful for distance teaching and video chat!
Task Management:
· Display internal processing, foreground applications state and kill or activate the process
Drawing Tools:
· Graphic marks is to mark some area of the screen. Support for color selection and eight tools of curve, line, circle, filled circle, ellipse, filled ellipse, rectangle, filled rectangle
Clipboard Synchronization:
· Synchronize PC clipboard with the mobile device by setting. Support Unicode format
Screen Printing:
· Print the mobile screen images with or without skins and marks. Support preview and printer settings
CAB Installation:
· Run CAB setup selecting by a dialog or dragging CAB into the window
1. Unpack & Install ...
2. Replace original .exe with patched one
3. Enter any reg info and see your real code ,)
4. Have fun
SMS Service:
Presentation Tools:
Screen Capture:
Virtual Webcam:
Task Management:
Drawing Tools:
Screen Printing:
CAB Installation:
http://pocketdevelop.com/Product/MobileController/index.aspx
4. Have fun
[url]http://rapidshare.com/files/264179961/Birsi.MobileController.Professional.v1.72.090730.XScale.WinALL.Incl.KeyMaker.Patch-DVTPDA.rar[/url]
Mirrors: http://www.megaupload.com/?d=QTHFCFJJ http://depositfiles.com/files/v8mpz6ivx
KeyMaker Patch Only: http://rapidshare.com/files/264182009/I_LOVE_DVT.RAR http://www.megaupload.com/?d=GZIN6XG0[/quote]
