I DO NOT TAKE CREDIT FOR THIS ROM THIS IS ALL ptfdmedic AT PPCGEEKS
OK. I think I am going to take a slightly different approach to these releases. Instead of numbering my ROM's I am going to name my ROM instead. For example midNIGHT, Singularity ect. I think this will make it easier to identify in the future.
I will keep several builds and kitchens posted at a time. Most likely the change in ROMs will come with the release of new builds but not always. I will also try to upload the matching kitchen to make things easier.
Your phone must be unlocked in order to flash these ROMS.
JD put a tut together for flashing.
If you are unsure of what you are doing ask. Also there is a search button that you can use to find answers.
I am not responsible if you brick your phone. So read before you do anything.
I want to make sure my THANKS go out first.
Calk for his kitchen and some OEM's and themes
Da-Reeseboy for the SYS and ROM
Groove for some OEM's and Visual Kitchen
I am sorry if I forgot anyone, but thanks to all the cooks in this forum.
This is the Singularity ROM. Windows Mobile 6.5 Build 23009
This is the Singularity ROM. This includes very basic HTC software. The ROM includes the following:
This is a SPRINT ROM.
+HTC Black S2A (fully working)
+black HTC calc (topaz)
+HTC USB to PC (updated and fully working)
+Fully Working GPS Drivers
+.net ALL
+.net Config
+iContact
+Windows Live
+Widgets
+Finger keyboard
+new filesystem drivers
+enhanced video drivers
+custom System Status
+weather and favorites Panels
+contacts panel
*Thats about it.
A few notes:
1) all contact links are re-directed to iContact
2) restored default wireless manager
3) pagepool is set by defalt to 24mb
4) this is a SPRINT ROM. ONLY LET CUSTOMIZATIONS RUN IF YOUR ARE WITH SPRINT.
5) customized cabs are available at the following http://forum.ppcgeeks.com/showthread...84#post1033484
-these cabs are modified so they install to the same locations as the oem versions. This way they can more easily be updated.
6) the default theme is Gloss Black. You will need to reselect in the settings in order to get the gloss bars.
Please leave feedback so I know what I can improve on. Thanks
Be Gentle and please don't forget to hit the THANKS button to let me know you like my work and I will keep them coming.
DOWNLOAD LINK
midNIGHT v2 ROM Singularity Edition build 23009 WORKING GPS
Singularity Kitchen (WORKING GPS) I cannot remember if I included a generic carrier in the kitchen. I attached it below. Replace the sprint carrier in the oem folder.
This is the Genesis ROM Windows Mobile 6.5 Build 21828
Here is a sneak peak
This ROM is different because it almost completely stripped of everything.
The reason is becasue the new file system filters only improve performance on things installed via cab post flash. So with that in mind I have left out things like Windows Live, JetCet Print ect. I will try to have as many cabs as I can posted when this releases. This way you will recieve the benefit of the performance enhancements.
This ROM has been unlocked so that you can install unsigned widgets. Please see the attached widgets file with 50 widgets.
Genesis ROM WM 6.5 Build 21828
CABS
Genesis Kitchen 21282
+.net ALL
+.net Config
+iContact
+Windows Live
+Widgets
+Finger keyboard
+contacts panel
*Thats about it.
A few notes:
DOWNLOAD LINK
CABS
