MEPMedia BurnPro 41
  • GokuSS3
    • Jun 02
    • 2247
    • HtC ToUcH PrIzZo 2
    • T-Mobile
    [RELEASE] MEPMedia BurnPro 41
    BurnPro is a burning application tool to simplify your burning needs. From now on, it’s really easy to burn Audio CD, Data CD/DVD’s, create Video DVD’s (S)Video CD’s, create and burn disc images, and more! It gives easy access to all functionality with a simple menu system, so you don’t get lost. Just click, add files and burn!
    Do you want to create CD/DVDs fast? Without a lot of options you dont really need? Then you need BurnPro! A plain and simple, but powerful program that does what you want:
    Dot Burn and update data discs: Burn data to discs and update previously burned discs by adding and removing files and folders. Dot Rip and burn music: Rip music from CDs and burn music to audio CDs and MP3 discs on CD, DVD and Blu-ray in a variety of formats. Dot Burn movies to DVDs and data discs: In addition to the new slideshow DVDs you can burn video DVDs, Video CDs (VCD), Super Video CDs (SVCD) and data video discs.
    Dot Copy CDs, DVDs and Blu-ray discs: Just insert a disc, select Copy to image/ Burn disc from image and youre ready to copy.
    What can you do with BurnPro?
    Burn your music!
    Create Audio CDs
    - Audio CDs can be played on any CD Player
    - WAV/MP3/WMA and Ogg Vorbis are supported
    Create MP3 CD/DVD
    - Can be played directly with CDDVD players with MP3 support
    Create WMA CD/DVD
    - Can be played directly with CDDVD players with WMA support
    Burn your data!
    Backup your precious data like photos, movies and other stuff from your hard disk before its to late! Within a few clicks you have created a backup on CD or DVD.
    BurnPro supports Multi Layer DVDs with a capacity of 8,5 Gb.
    Not ready to burn your project yet? Just save all project data for later use.
    Backing up data couldnt be easier!
    Burn your video!
    Need to view your holiday movies on TV? Or do you want to burn a DVD you just copied with other authoring software? No problem with BurnPro. Just add MPEG-1 or MPEG-2 files to the project list, and create your (S)uper Video CD.
    If you need to burn a DVD, you only need to give the path with the DVD files, and BurnPro takes care of the rest.
    Create (S)Video CD
    - Can be played with most DVD players
    Create Video DVD from prepared folder
    - Burn Video DVD from your ripped DVD
    Burn or create disc images!
    Burn ISO/BIN or CUE files to CD/DVD
    - Create a CD/DVD from ISO/CUE/BIN disc image
    Create ISO disc image
    - Create ISO images from CD or data on your hard disk
    - Works under Windows 98/Me/NT/2000/XP/2003/Vista operating system (or higher)
    - Easy to use interface
    - Create Audio CDs from WAV/WMA/MP3/Ogg Vorbis audio files
    - Burn movies as Video DVD, Video CD or Super Video CD
    - Create and burn disc images to CD/DVD
    - Load and save project files
    - Erase CD-RW, DVD-RW+
    - Create Data CD/DVDs
    - DVD Dual Layer supported
    - Burnproof supported
    - Drag & Drop functionality
    - And much more!
    Install Notes:
    Install this application and register with serial.
    Release Name: MEPMedia.BurnPro.v4.1.Regged-QUANTiZE
    http://hotfile.com/dl/9761163/8b3bd41/MEPMedia.BurnPro.v4.1_Full.rar.html
    OR
    http://rapidshare.com/files/264186032/MEPMedia.BurnPro.v4.1_Full.rar
    If I Have Helped Be Sure To Hit That Thanks Button!!!
