Advanced PC Tweaker v42
  • Superman369
    • Sep 22
    • 2084
    • Touch Prizo!!!
    [RELEASE] Advanced PC Tweaker v42
    OP:
    http://www.project-os.org/forums/viewtopic.php?f=18&t=29205&hilit=freezing+windows+7
    Why Use Advanced PC Tweaker?
    Does your PC run more and more slowly?
    Do you get the ActiveX or similar .dll errors?
    Does your computer pop up mysterious error messages?
    Do you suffer from the system's memory strike all the time?
    Are you afraid of being tracked when you are surfing the Internet?
    Are you troubled with the blue screen, system crashing or system freezing from time to time?
    Our results-oriented solutions are professionally designed for Windows© PCs to avoid re-installing the operating system. Advanced PC Tweaker is a complete package for your PC care and maintenance that you don't have to go through the hassles of resolving the problems and with Advanced PC Tweaker you can safely clean and repair the registry problems and speed up your computer with a few simple clicks.
    Intuitive and Straightforward Interface:
    It is designed to be a very easy, intuitive and effective to use for scanning, repairing PC problems and optimizing the performance with a few clicks.
    Repairs Problems with Registry Cleaner:
    Advanced PC Tweaker can thoroughly scan and effectively fix the Registry problems on your PC system, ensuring a better and more reliable performance through reparing a variety of 17 categories.
    Advanced PC Tweaker Repairs Problems with Errors Utility:
    Error Utility scans and fixes the commonly-known Windows system errors to protect the Windows system from crashing, freezing and blue screen problems.
    Advanced PC Tweaker Repairs Problems with IE Repair:
    IE Repair includes BHO (Internet Browser Helper Objects) Manager and IE Restore to ensure a better and healthier internet experience by blocking malicious plugins and restore Internet Explorer to the original states respectively.
    Advanced PC Tweaker Repairs Problems with Block ActiveX:
    Block ActiveX and Register ActiveX can be used to manage and fix the ActiveX controls (objects)in order to terminate misbehaving controls (objects) and solve the curious problems on your system.
    Advanced PC Tweaker Repairs Problems with Register ActiveX:
    Free up Disk Space with Junk File Cleaner:
    With the Junk File Cleaner, Advanced PC Tweaker can scan and clean up the junk files from your system to provide more free space on your hard drives and allow applications to run faster and more efficiently;
    Free up Disk Space with Duplicate Cleaner:
    Duplicate Cleaner scans and cleans the duplicate files with same name on your local computer, which as its name suggests are files that could also have the same size, the same time. Your system may have many duplicate files that use your precious disk space. These duplicate files not only occupy your disk space but also make your system's file access rate slow.
    Create, Restore and Remove Registry Backups:
    Advanced PC Tweaker will automatically backup your registry files prior to any registry repairing and let you manage the files within the Registry Backup utility.
    Manage Backups with Restore Point:
    You can also back up the whole system settings with the built-in Restore Point utility which can be used to create and name the restore points at any given time.
    Optimize System Performance with System Optimizer:
    System Optimizer utility can automatically optimize the model of your selection to the optimal speed by disabling unnecessary applications or services.
    Optimize System Performance with Memory Tweaker:
    Tweak Memory tweaks the memory of your PC system, recovers the memory and makes your PC run faster without causing instability of your system.
    Remove all Privacy Trackings with Evidence Cleaner:
    Evidence cleaner can completely remove all traces of your Internet activity and protect sensitive information while improving your computer's performance
    Administer Applications upon Startup:
    Use Startup Manager to administer which applications are launched at the system startup
    Uninstall any Unwanted Programs with Uninstall Manager:
    Uninstall Manager to manage and completely remove the programs and leftover files installed on your system without going through the Control Panel.
    File Shredder to Permanently Remove Files:
    File Shredder can permanently remove the specific files from your drives.
    Service is also a Great Feature:
    When you are using Advanced PC Tweaker, you are not only having the handy toolkits but also the great services by our professionals.
    [DOWNLOAD].[/DOWNLOAD]
    http://rapidshare.com/files/251514768/APC_T4.2-_XLR8.rar
    Got a ? Use The Help Desk Here
    Need it all in one thread?Click Here
    Learn How To Flash A Rom?Click Here
    Are You New To The Scene?Click Here
    Need to Learn How To Search? Click Here
    The End All, Be All of Noob Guides.Click Here
    Make Sure You Hit The Thanks And/Or Installed Buttons If Someone Helps You Or You Use There Programs!!!
  • mispook08
    • 3014
    • HTC Vogue (Sprint Touch)
    Re: Advanced PC Tweaker v42
    Is there any way i can gt the keygen for this ?
      he bro theres a keygen in the files your antivirus must of snath it since il check this just put your antivirus off tested it clean
      ADMINISTRATOR@SPJ
      • mispook08
        • 3014
        ADMINISTRATOR@SPJ
        Yea bro i didnt find on in the RAR thanks weesjie
