R-Studio Network Edition 50 Build 129011
  • Superman369
    • Sep 22
    • 2084
    • Touch Prizo!!!
    [RELEASE] R-Studio Network Edition 50 Build 129011
    R-Studio is a family of powerful and cost-effective undelete and data recovery software.
    Empowered by the new unique data recovery technologies, it is the most comprehensive data recovery solution for recovery files from FAT12/16/32, NTFS, NTFS5 (created or updated by Windows 2000/XP/2003), Ext2FS/Ext3FS (LINUX file systems) and UFS1/UFS2 (FreeBSD/OpenBSD/NetBSD file systems) partitions. It functions on local and network disks, even if such partitions are formatted, damaged or deleted. Flexible parameter settings give you absolute control over data recovery.
    R-Studio utilities recover files:
    * Deleted without Recycle Bin, or when Recycle Bin has been emptied;
    * Removed by virus attack or power failure;
    * After the partition with the files was reformatted, even for different file system;
    * When the partition structure on a hard disk was changed or damaged. In this case, R-Studio utilities can scan the hard disk trying to find previously existed partitions and recover files from found partitions.
    * From hard disk with bad sectors. R-Studio Data Recovery Software can first copy the entire disk or its part into an image file and then process such image file. This is especially useful when new bad sectors are constantly appearing on the hard disk, and remaining information must be immediately saved.
    * Standard "Windows Explorer"
    * style interface.
    * Host OS: Windows 9x, ME, NT, 2000, XP, 2003 Server, Vista.
    * Data recovery over the Network. Files can be recovered on network computers running Win95/98/ME/NT/2000/XP/2003/Vista, Macintosh, Linux and UNIX.
    * Supported file systems: FAT12, FAT16, FAT32,NTFS, NTFS5 (created or updated by Win2000/XP/2003/Vista), HFS/HFS+ (Macintosh), Little and Big Endian variants of UFS1/UFS2 (FreeBSD/OpenBSD/NetBSD/Solaris) and Ext2FS/Ext3FS (Linux).
    * Recognition and parsing Dynamic (Windows 2000/XP/2003/Vista), Basic(MBR) and BSD (UNIX) partitions layout schema and Apple partition map. Dynamic partitions over GPT are supported as well as dynamic partitions over MBR.
    * Damaged RAID recovery. If OS cannot recognize your RAID, you can create a virtual RAID from its components. Such virtual RAID can be processed like a real one.
    * Creates IMAGE FILES for an entire Hard Disk, Partition or its part. Such image files can be compressed and split into several files to put it on CD/DVD/Flash or FAT16/FAT32. Then the image files can be processed like regular disks.
    Data recovery on damaged or deleted partitions, encrypted files (NTFS 5), alternative data streams (NTFS, NTFS 5).
    * Recovering data if:
    o FDISK or other disk utilities have been run;
    o VIRUS has invaded; FAT is damaged; MBR is destroyed.
    * Recognizes localized names.
    * Recovered files can be saved on any (including network) disks accessible by the host operating system.
    * File or disk content can be viewed and edited with the advanced hexadecimal editor. The editor supports NTFS file attribute editing.
    New R-Studio features in version 5.x:
    * RAID 6 support, including Reed-Solomon and Vertical XOR. Support for custom-specified RAID 6 layouts.
    * Advanced object copy. In addition to byte to byte copy of any object visible in the Drives panel, smart copy of partitions and hard drives with size and offset adjustment is available.
    * Support for 64- and 32-bit Windows versions. Under a 64-bit Windows, R-Studio overcomes the 3GB RAM limit for a 32-bit application and utilizes all physical RAM installed in the 64-bit Windows machine. This greatly enhances performance of the software, especially when scanning high-capacity disks.
    [DOWNLOAD].[/DOWNLOAD]
    http://www.gazup.com/WD8Kb-r-studio_5.0_build_129011.rar-download-mirrors
    http://hotfile.com/dl/9928364/de6415a/R-Studio_5.0_Build_129011.rar.html
    http://www.filebox.ro/download.php?key=s5yhdy6tla6s9f82
    http://www.midupload.com/4grg9ffv74ez
    http://uploadbox.com/files/021ec6b56b/
    http://depositfiles.com/files/p42d46nt4
    http://uploading.com/files/KIMXSTEP/R-Studio_5.0_Build_129011.rar.html
    [PASSWORD]
    the crow[/PASSWORD]
    Got a ? Use The Help Desk Here
    Need it all in one thread?Click Here
    Learn How To Flash A Rom?Click Here
    Are You New To The Scene?Click Here
    Need to Learn How To Search? Click Here
    The End All, Be All of Noob Guides.Click Here
    Make Sure You Hit The Thanks And/Or Installed Buttons If Someone Helps You Or You Use There Programs!!!
