MSS Converter v108
  • forty01
    Supporter
    • Nov 24
    • 1169
    • HTC Touch Pro/HERO
    MSS Converter v108
    MSS Converter v1.08
    Requirements: Pocket PC sous Windows WM 2003, WM 5, WM 6
    -MSS Converter allows to make conversions between many units. Supported units are currencies (with the ability to automatic update rates), lengths, areas, volumes, masses, speeds, temperatures, pressures, times, angles, energies, powers, radiations, forces, angular speeds (and frequencies), computer units, viscosities, luminosity units, magnetism, torques, flow rates and fuel consumption. The software is easy to use. You can setup the units to show or hide.
    -The software supports VGA and QVGA resolutions, with portrait, landscape or square screens. To install the software, unzip and copy the .cab file onto your pocket PC (via a memory card or ActiveSync), then execute it using the file manager. On the first run of the software, you can setup the language to use. Needless languages are deleted to increase free memory space.
    *Version 1.08
    - Add of the Centipoise unit
    - Millipascal-second formula fixed
    - Bug fixed in main page display for PDA with square screen
    - Better WVGA screen management
    - Use of combo box for units (allow a better space management)
    - Use of Tool Tips when the stylus stays on an icon, indicating the category in text format
    More info: http://micromeg.free.fr/progs.html#MSSConverter
    About the "I Win" Champion Click Here
    Flashing a ROM Click Here
    Noob Zone Click Here
    How to Search for...? Click Here
