How To: Add voices to TomTom for iPhone
Voices:
English Celebrity voices:
English More Celebrity voices:
To change the voices:
1. Select the celebrity voice "dataxx.chk" & dataxx.vif" from the folder and copy to desktop.
2. Rename the files to one of those found in the TomTom app. They start at "data00.chk" and "data00.vif" and go up to about 60. the data00" files are those of "Dansk - Brigitte". I haven't checked the rest.
3. There are 2 ways of doing the next step.
First way: SSH into your iPhone and find the TomTom application folder.
Once in the TomTom folder got to the folder "voices". On my iPhone it was located in "private/ver/mobile/applications/xxxxxxxx-xxxx-x....../US-Canada app/voices"
Second way: Right click the tomtom ipa file and open it with winrar. Extract the contents to a folder. Next, open the folder and go to /voices. Now you can go to step 4. Once you did that, go back up to the folder you extracted the ipa in, select all the files and add them to a zip archive. Next, rename the .zip file back to ipa and sync it with iTunes.
4. Drag your newly renames files from your desktop into the voices folder on your iphone. You will be prompted if you want to overwrite. I did. But you might want to make a backup of the originals before you do.
5. Now you can open your TomTom app on your iPhone and go to Settings then voices. If you used the file names with "00" then you can select the voice of "Dansk - Brigitte" and low and behold you will have your celebrity voice.
Voices:
http://rapidshare.com/files/268782272/Voices_and_Pictures.rar
http://rapidshare.com/files/268782409/MoreCelebrityVoices.rar
