DVR Remote v2.1
Requirements: Compatible with iPhone and iPod touch, Requires iPhone OS 2.2.1 or later
Overview: DVR Remote is an iPhone application for managing your TiVo Series 3 DVR. You can remote control the unit and browse your Now Playing information wirelessly on your iPhone.
FEATURES:
• Control your TiVo DVR over your wifi network - channel surf, skip commercials, it's all here
• TiVo DVRs are automatically detected - no IP entry required
• Remote control your TiVo Series 3 over your wifi connection
• Fast text entry makes searching on the DVR a joy (including YouTube - just swipe to select the red keyboard)
• Favorites list gives fast access to your frequently viewed channels
• View Now Playing information on your iPhone or iPod Touch
• Edit the button layout - buttons "dance" while editing like the iPhone home screen
• Embedded browser for TiVo Mobile - Find and schedule shows the easy way
• Customize the interface with skins - even make your own!
REQUIREMENTS:
• TiVo Series 3, TiVo HD or TiVo HD XL DVR
• Wireless network on the same subnet as the DVR with Bonjour support
• iPhone or iPod Touch Running OS 2.2.1 or higher
Mirror:
FEATURES:
REQUIREMENTS:
http://www.stutsmansoft.com/dvrremote
http://rapidshare.com/files/274272488/DVR.Remote.v2.01.iPhone.iPod.Touch.Cracked-COREPDA.rar
http://ul.to/hrolfc
