Palm Pre theme which revolves around the colors red and black. This theme skins the entire WebOS. First revolutionary theme available to the Pre Community that affects the entire WebOS.
You will never look at your Pre the same way again. This theme will set a new standard for the next generation of themes.
Disclaimer: I, Abyssul, accept no liability for any damage this theme causes. This theme is still in the beta phase and unfinished.
You are under risk of OS corruption if this theme is installed on WebOS 1.2.
can be downloaded and originally found here:
http://www.precentral.net/webos-themes/flash-red-and-black
