TF3D Retractable Manila Slide Bar V0.12 VGA and WVGA Beta 3
  • elboriyorker
    OG Member
    • Nov 08
    • 9328
    • Metro
    [FREEWARE] TF3D Retractable Manila Slide Bar V0.12 VGA and WVGA Beta 3
    Hello guys i have tested this on my touch pro and works .
    TF3D Retractable Manila Slide Bar is a mod for Rhodium Manila. It allow to retract manila slide bar in protrait mode like in landscape mode.
    Specification:
    • Retractable Slide Bar for all tabs
    • Timeout
    To do:
    • Select tab where Slide Bar is retractable
    • Add notification bubble for new SMS, miss call...
    History:
    • Version 0.12 HD Beta 3
      • Third try. Work on some version of manila. But not on all versions.
    • Version 0.12 HD Beta 2
      • A new try
    • Version 0.12 HD Beta 1
      • First version for the Touch HD (This is a beta. Not tested at this time)
    • Version 0.12
      • Fix one bug : When selection is not done by sliding but by taping, the slide bar doesn't retract.
      • Code improvement : This version is really faster.
    • Version 0.11
      • Fix one bug : Inversion of the color Black/white when going to the second level in Manila.
    • Version 0.1
      • First release
    Known issues:
    • The slide bar doesn't retract when weather tab is select. Need to retap on the slide bar and after time-up, it retracts. This problem come from Manila Weather tab itself. Can't fix it by Manila slide bar code. Try to fix it separately.
    • up button for slide bar appeared when not needed (Slide bar is empty)
    Installation:
    • Install RHODIUM Manila to device
    • Install TF3D RMSB cab file to device (WVGA is still a beta, please process a backup before)
    • Restart your TF3D
    • Enjoy
    Source of link for download: HERE
    I did not receive permission from the author yet, to upload his cab file once i get approval then i'll attached it mean time you can go to the link and download it there.
    SPJ Bulletin @
    www.smartphonejunkie.org
    Re: TF3D Retractable Manila Slide Bar V0.12 VGA and WVGA Beta 3
    any pics? thee attach pics from the site you got this from arent working.
    • elboriyorker
      OG Member
      • Nov 08
      • 9328
      • Metro
      yea give me a sec i forgot they host images like i do to stop leeching ...lol
      SPJ Bulletin @
        hahahha word and it is a good idea :)
        • elboriyorker
          OG Member
          • Nov 08
          • 9328
          • Metro
          lol images attached
          SPJ Bulletin @
