SPBMobileShellv353 XScaleWM5WM6InclKeymaker 12/29
    [UPDATES] SPBMobileShellv353 XScaleWM5WM6InclKeymaker 12/29
    https://www.youtube.com/watch?v=WmvDr7wAPFQ
    Cool widgets to customize your Home screen
    Photo contacts
    Picture frame
    Media player
    Weather
    Internet search
    Facebook and Twitter status
    Wireless switches
    Phone profile
    Appointments and tasks
    ... and many others
    Customize your device with your preferences
    3D carousel with special effects
    Make your own Home screen using widgets
    Adaptive skins
    Change background
    Customize your menu
    Change widget skins
    Choose Professional or Lifestyle Home screen
    SPB Mobile Shell comes with integrated tools
    Weather forecasts
    Current weather
    Agenda view
    World time
    Wireless switches
    Profiles
    Internet search
    Finger friendly contacts with Facebook integration
    Widget-based photo contacts
    Photo call log
    Smart contact search
    3D favorite contacts carousel
    Ringtone management
    Category filter
    Version 3.5.1 beta 1 (Nov 03, 2009):
    Key bug fixes and changes:
    * SPB Pocket Plus close button makes Shell unresponsive
    * Set Ringtone doesn't work for Contacts
    * 6.5: Theme shows incorrectly for Carousel and Tiles views
    * Added current conditions threshold for weather widget
    * Agenda: One day is shown twice, 25 осt date is the transition to "winter" time
    * 3D SMS viewer: First word disappears after enter
    * Twitter issues fixes
    * Kinetic scrolling doesn't stop on Asus P565
    * 3D SMS viewer: Picture is absent.
    * 3D viewer: Date isn't shown for SMS and Email
    * 3D email viewer: First account always shows
    * Birthday widget doesn't update itself when contact info is changed
    * New filter category is available only after MS restart
    * Task widget makes task sychronization with Outlook longer
    * Feature: introduced default action for weather widget (now choose between "Open forecast" and "Open conditions")
    Build.9593
    SERIALS THE FIRST ONE WORKT FOR ME BE QUICK LOL
    5D5G3473M852
    5D5H24C922B6
    5D5M8246A4H4
    5D54F253596C
    5D5247F329M7
    5D5F38A4397C
    5D542AJ247C4
    5D527222DD55
    5D597325K2H9
    5D5G4257C84C
    5D577752A43K
    5D5E98A54AE2
    5D5243747BD3
    http://www.ziddu.com/download/6699057/SPB.Mobile.Shell.KG.exe.html
    NEW RELEAS 4/11
    Version 8.0.6
    * Fix installer problems on Windows 7.
    * Add Delete Source Files After Sync (Move Files) job option.
    * Do not consider drives A: and B: to be portable when searching for portable volume.
    * Allow to Pause during Reconnect.
    * Fix File Compare for remote file systems.
    * Remove Quick Backup Mode, as it was confusing and can lead to sync problems.
    * Allow job whose names contain dot to be Scheduled.
    Version 3.5.1 (Nov 11, 2009):
    * Fix: SPB Pocket Plus close button makes Shell unresponsive
    * Fix: Set Ringtone doesn't work for Contacts
    * Fix: Added current conditions threshold for weather widget
    * Fix: Agenda: One day is shown twice, 25 осt date is the transition to "winter" time
    * Fix: 3D SMS viewer: First word disappears after enter
    * Fix: Twitter issues fixes
    * Fix: Kinetic scrolling doesn't stop on Asus P565
    * Fix: 3D SMS viewer: Picture is absent
    * Fix: 3D viewer: Date isn't shown for SMS and Email
    * Fix: 3D email viewer: First account always shows
    * Fix: Birthday widget doesn't update itself when contact info is changed
    * Fix: New filter category is available only after MS restart
    * Fix: Task widget makes task sychronization with Outlook longer
    * Fix: Appointment list can become empty
    Version 3.5.2 (Dec 09, 2009):
    • Fixed issue with SMS opening on HTC HD2
    • Fixed issue with alarms on HTC HD2
    • Fixed issue with settings opening on HTC Windows Mobile 6.5 devices
    • Backlight support for new devices
    • Added a possibility to send MMS from an unnamed calllog entryspbs
    Spb Mobile Shell v3.5.2.Build.9745.Cracked-Dasai
    [download]http://www.megaupload.com/?d=8DAS8V84[/download]
    NEW RELEAS 12/11 3.5.1 build 9687
    http://www.megaupload.com/?d=OTXW41JN
    NEW RELEAS 3.5.2 ADDED 12/9
    http://www.megaupload.com/?d=AKRWLWHW
    NetLoad
    http://netload.in/dateidrsD75fvxE/SPB.Mobile.Shell.v3.5.2.XScale.WM5.WM6.Incl.Keymaker-COREPDA.rar.htm
    Hotfile
    http://hotfile.com/dl/21638163/a3a4abc/SPB.Mobile.Shell.v3.5.2.XScale.WM5.WM6.Incl.Keymaker-COREPDA.rar.html
    Version 3.5.3 (Dec 29, 2009):
    * OpenGL ES 2.0 support in SPB Carousel
    * Windows Mobile 6.5 icons support
    * Miscellaneous bug fixes and optimizations
    NEW RELEAS 12/29
    http://rapidshare.com/files/327501442/SpbMobileShell3.arm.cab
    http://www.ziddu.com/download/6702245/SPB.Mobile.Shell.KG.New.exe.html
    CRACKED ONE NEW 12/29 build 9885
    http://rapidshare.com/files/327603563/SPB.Mobile.Shell.v3.5.3.Build.9885-RCAPDA.cab
  • Mike20PR
    SPJ Trend Setter ADMIN
    • Mar 31
    • 2453
    • Touch Pro 2
    Re: SPB Mobile Shell 35 NEW OUT
    needed the serial.
    thanx and installed
    ....................Ultimate NOOB Guide CLICK HERE....................
    ....................PPC Guide For Dummies CLICK HERE....................
    ....................Dont Know How To Flash A ROM? CLICK HERE..................
    ....................Learn To Search CLICK HERE....................
    • MikeyD
      Find Em Hot Leave Em Wet
      • Apr 25
      • 1609
      • TP2, omnia, Mogul
      • Can You Hear Me Now
      thanked and installed for ya cyber.......man i like the new look and feel even for just using the stock one with no theme
      Can't Access Something Click Here
      Can't Find Something Click Here
      Need Help, Check Out the Help Desk Click Here
      IF SOMEONE HELPS YOU HIT THE "THANKS" BUTTON
      FOLLOW THE RULES
      AND PLEASE CLICK INSTALL ON ALL APPS AND THEMES
      PLEASE POST SOMETHING, ANYTHING HERE
      • VenumX
        The VenumX Factor
        • Nov 14
        • 1410
        • HTC Touch PRO
        sexy...goodbye tf3d :P
        ("Do Not Pm Me Or Email For Support" For Mobile Stuff, Post your question/problem on the forum so that someone else who's having the same issue can benefit from the solution.)
        Wanna Introduce Yourself?! Click HERE
        Need to flash a rom?
        stlouisfinest68 has a great video tutorial on how to do it, click HERE
        Forum Rules: --> HERE
        Join A Group:--> HERE
        Learn To Get Around The Forum:--> HERE
        • MikeyD
          • Apr 25
          • 1609
          • TP2, omnia, Mogul
          how do you get the 3d carousel
          FOLLOW THE RULES
            he bro swap down the carrousel whent its in the background if you click right button you can use gsensor
            ADMINISTRATOR@SPJ
            • chauleyb
              • Feb 19
              • 129
              • touch pro
              i jus fell in love very nice
              • MikeyD
                • Apr 25
                • 1609
                • TP2, omnia, Mogul
                make sure you hit the thanks and install if you download this
                FOLLOW THE RULES
                  so what do you guys think of it.... is it really that much different use wise thanthe old version 3.XX? or is it just flashier version of that as tf3d 2 is for tf3d
                  • MikeyD
                    • Apr 25
                    • 1609
                    • TP2, omnia, Mogul
                    I like it....it has a good look and feel a lot fresher than 3.0 was.....they have improved on a lot features i love the text email 3d view and icon changes you can choose like default or professional. all in all 4 out of 5 because of a few liknesses to the original 3.0
                    FOLLOW THE RULES
                      cool gonna have to hold out though for some more widgets.... doesnt do all i would want it to from there... when the widgets come out in numbers that are useful i will def give this a whirl.
                      • MikeyD
                        • Apr 25
                        • 1609
                        • TP2, omnia, Mogul
                        #12
                        more widgets would be cool
                        FOLLOW THE RULES
                          or even a source code/generator wehre the users and the community could easily make widgets to use and share with all..... that would make mobile shell a beast of an interface.... im gonna have to give my contact a call through them and mention that idea to them and see if i can convince them to spend the time and money on doing so.
                          • MikeyD
                            • Apr 25
                            • 1609
                            • TP2, omnia, Mogul
                            #14
                            wow great idea that would def keep me on board with them
                            FOLLOW THE RULES
                            • tlpalmer01
                              • Feb 20
                              • 1050
                              • htc touch pro
                              #15
                              weesje u da bomb.....thank u thank u...gotta download....sweet.......
