Hi guys:
This is the new version of Hero Like Theme for ThrottleLauncher.
Now have a lot of improvements thanks to TL RC3.
Its compatible with all resolution( I ask a few members to test it in their devices).
The mode to use this theme was change a little, no more gesture to open pages or open menu box.
This is the instructions:
Installation :
Unzip the file inside your Setups folder
Some Notes:
the zip have 2 lock.xml
I recommend to use the lock nitrogencontrol.xml if you use nitrogen version 1.1 and if you have installed in main memory. For use that rename lock nitrogencontrol.xml to lock.xml
I you, like me, use nitrogen 1.2 alpha4 so use the default lock.xml.
PLEASE CONFIG FIRST BEFORE USE THE THEME.
Original Link:
Installation :
Some Notes:
Original Link:
http://www.throttlelauncher.com/portal/component/option,com_sobi2/Itemid,99/catid,5/sobi2Id,541/sobi2Task,sobi2Details/
