TeaTimer is a simple app to help prevent bitter tea, nobody likes that. Its still rough around the edges and I have a list of features left to implement, but I wanted to get some feedback before I got too far. I have learned many times that what makes sense to me isn't always what makes sense to others.
Current verison: 0.6.0 (10/2/09)
This app is licensed under the GPL V2.
Known Issues:
Changlog:
Version 0.6.0
Version 0.5.0
Version 0.4.1
Version 0.4.0
Version 0.3.0
Version 0.2.0
Warning: Version 0.3.0 and newer use a different app id so delete TeaTimer manually before installing the new verison. This will erase all current app data.
originally found here:
Known Issues:
- None
Changlog:
Version 0.6.0
- Updated power management
- New time entry mode, the traditional MM:SS
Version 0.5.0
- Slight change to application flow
- Alarm vibrate option
- New alarm code
- New add/edit scene
- New tea amount option
- New tea notes options
Version 0.4.1
- New repeating alarm option
Version 0.4.0
- Move edit to the tea list view
- Add ability to filter tea list
- Add preference for alarm sound
- New alarm sound
Version 0.3.0
- Dashboard scene to go with notification
- Don't use notification sound, play it manually
- Disable power management for the duration of the timer
- Add Water Temp attribute
- Add Auto Start option
- New artwork courtesy of seanau.com
Version 0.2.0
- Added edit capabilities to the tea list
- Separated the tea list into a new scene
- Better error handling with the add/edit dialogs
- Fixed swipeToDelete issue with only the 'Delete' button appearing
http://forums.precentral.net/homebrew-apps/201786-teatimer.html
