Mobiion MagiCall v224
    [RELEASE] Mobiion MagiCall v224
    Mobiion MagiCall v2.2.4.
    Requirements: PocketPC 2003(SE), WM5, WM6
    Overview: MagiCall is a smart tool for bidirectional calls filtering and SMS filtering. It is the only product in the world that can not only filter incoming calls but also filter outgoing calls.
    With MagiCall, you have the ability to block unwanted callers, automatically hang up on someone bothering you, and more! Stop anyone you just don't feel like speaking to at the moment from disturbing you. Automatically add prefix number in front of the original dialing number based on your rule. Hang up predefined outgoing numbers such as international calls. In addition, you can also take control of your incoming SMS Messages. Reply back or forward SMS to someone or launch an application when a rule is being triggered. And it can log detail information about all triggered events to the log file.
    Version 2.2.2 | Jan-4-2009
    * Added new contextual parameter - {msg-clip}, which represents the content of a received SMS but excluding the matched keyword
    * Now supports negative logic in the [Phone #] field, by using a leading letter '~'
    * Now the notification window for ignoring will be kept after the remote party ends the call
    * Added a new command line parameter "-lv", used to show Log Viewer
    * Added supports to filter SMS sent from contacts' email addresses
    * Fixed: SMS Move causes exceptions when checked [Show notification] but not checked [Log events]
    * Fixed: Data connection lost for CDMA devices after hanging up a number of incoming calls
    * Fixed: Email Account option is not saved for the Smartphone version
    * Fixed: Keep Login Minutes option is not saved for the Smartphone version
    * Fixed: Program crashes when using Change Dialed Number: {phone}[-x,y], while the original phone number's length is equal to x+y
    * Fixed: An incompatible issue between MagiCall home plug-in and SBSH Facade
    * Fixed: Upgrades may cause the Today plugin and SMS filtering features not working
    GRTZ CYBER WEESKJE
    ADMINISTRATOR@SPJ HIT THANKS ON THE WAY OUT
  • forty01
    Supporter
    • Nov 24
    • 1169
    • HTC Touch Pro/HERO
    Re: Mobiion MagiCall v224
    I haven't tried this updated version and have never had any problems with my current. I love this program. It is a must have for me. I've been using this for years and can say nothing, but good things. Have fun.
    About the "I Win" Champion Click Here
    Flashing a ROM Click Here
    Noob Zone Click Here
    How to Search for...? Click Here
    • tsunami69
      Member
      • Aug 20
      • 66
      • htc 6800
      • Alltel
      Re Mobiion MagiCall v224
      This is a great program to have on your phone, especially for when u just dont want to talk to certain ppl. I would recommend this to any and everybody
      • Longfist
        • Apr 04
        • 292
        • several
        • quakor
        Verry interesting,block incomming calls etc.
        thnx m8
        • forty01
          Supporter
          • Nov 24
          • 1169
          thnx m8
          You can block an incoming call and then have an application open or send a text message out. That's just a couple of the things. You can use it for Google Voice(good if you do this on all calls/I do this for my daughters phone, so her real number is never given out). When you call out, it can call your Google Voice number, put in your password and then dial the number you wanted to call. It has many capabilities. It is a must program for myself as stated above.
          • tek
            Member
            • Nov 26
            • 95
            • HTC Touch Pro 2
            OKay I PMed Dash to make 100% sure it was okay to post this question. My old cracked Magicall doesnt work with my current ROM, The drop down menues wont drop. I saw this CAB was version 2, so I Downloaded it to give it a shot. It WORKS!! I can finally use the program. BUt I noticed it was in Trial mode and will Expire soon.
            Dash said I must have missed something for the serial. But I only see one Download and thats the CAB file.
            Wheres the Keygen??
            • forty01
              Supporter
              • Nov 24
              • 1169
              Wheres the Keygen??
              I'm not sure where the one for this version. I'm using another version before this, so I would search for another version and try the kgen's to see if they work on this. If they do, please post back letting us know it worked, thanks Tek.
                Wheres the Keygen??
                Hi attach cracked cab new releas register With any 5 Digit Number
                ADMINISTRATOR@SPJ
                • tek
                  Member
                  • Nov 26
                  • 95
                  • HTC Touch Pro 2
                  CYBER: I Think i missunderstood. I instsalled the CAB from this post and tried to reg with 12345. But it said it didnt match Owner Name. Was there somethign else I was supposed to do?
                  FORTY: I dont think that will work. But I will give it a shot now and let you know for certin.
                  EDIT: Oh crap. I just saw there was another CAB under the ENG CAB. I know that wasnt there before. I guess thats what you were talkin about Cyber. nm, trying that cab
                  --------- New Post Merged on 13/10/2009 at 0647 --------
                  EDIT (again) WOOOOOO!!!!! It works! I must have tried 5 dif call block apps. All useless since the phone still rings once. Thank you Cyber! You saved me alot of problems from my ex gf. I Thank you! My gf thanks you! and I think I just devolped a man crush. lmao. Anyway thanks a million.
                  FORTY: I just installed the 2nd CAB and like Cyb said. reg with any 5 numbers.
                  • forty01
                    Supporter
                    • Nov 24
                    • 1169
                    Good deal. 2nd cab wasn't there before, thanks CW. Like I stated before program works great. I need to see what if any major improvements have been made from this version to the last. At the moment not seeing anything major, so I'll just stick with what I have. I have 5+ different settings with specific instructions to accomplish certain tasks when calls are made in or outbound. Good Luck.
                    • tek
                      Member
                      • Nov 26
                      • 95
                      • HTC Touch Pro 2
                      Hey CYBER, Thay 2nd CAB that you added. Thats the only one that people need to Download. When I installed the Energy ROM 2 days ago, I Just installed the Bottom CAB and its reged and works. So I wasnt sure if maybe you wanted to remove the magicall_ENG CAB since people dont need it.
                      JUst thought maybe it would confuse people if they didnt know which one to DL.
                      • mzlady26
                        mzlady26
                        • Jan 17
                        • 1324
                        • Touch PRO
                        • SPRINT
                        #12
                        Oooops. I should have posted this way way way way 6 days ago when I downloaded this app. This is great and I love it, cause it works so well and fits right into my life style. Great program and I don't think they could do anything better with this.
                        Sexxy 1
                        • forty01
                          Supporter
                          • Nov 24
                          • 1169
                          I'm going to agree with you on this. They would really have to take a step back and add something that really is unique. I love this app as stated before and I wish they hd it for Android, because I'm missing it :(
                          The HERO does have a feature that you can send contacts directly to voicemail(neat that it's built in), but nothing like the control of Magicall... nothing.
