Grunge Panoramic Style By PB - Portrait And Landscape BETA
  • elboriyorker
    OG Member
    • Nov 08
    • 9328
    • Metro
    [BETA] Grunge Panoramic Style By PB - Portrait And Landscape BETA
    Another creation using the grunge style.Because i like the solid or matted type images.This will be posted here till i see that this will be a hit for spj then i'll move it to an appropriate section.
    I created it for both for portrait and landscape mode and i have tested this with out any issues.
    How to:
    1. Download cab file
    2. put it in either document or storage card
    3. install it, then follow the command to re-start
    4. See it in action
    I was able to port it to a cab file so you can uninstall it anytime..
    This is used on the touchpro using NSFAN ROM. Others may vary i have not tested it on other rom or device.
    SPJ Bulletin @
    www.smartphonejunkie.org
  • elboriyorker
    OG Member
    • Nov 08
    • 9328
    • Metro
    Re: Grunge Panoramic Style By PB - Portrait And Landscape BETA
    Added cab TSK File enjoy
    Download tsk file put it in the template directory in my document NOT YOUR HOME PC but your pocket pc
    then download this tool here DOWNLOAD thanks to phe-nom and change the task bar color.
    SPJ Bulletin @
      looking good pb :) you are a beast!
      • Steelpen2
        • Mar 03
        • 1637
        • HTC Mogul
        looks very nice pb! great job
        • elboriyorker
          OG Member
          • Nov 08
          • 9328
          • Metro
          thanks guy.. the only issue i ran into is the tsk file i changed the task bar to black but on my phone is showing that gray glossy color doing research to try and adjust that
          SPJ Bulletin @
          • Steelpen2
            • Mar 03
            • 1637
            • HTC Mogul
            i haven't done themes in like forever so i have no idea what you're talking about hahaha
            • elboriyorker
              OG Member
              • Nov 08
              • 9328
              • Metro
              lol i'll show you better see attach
              SPJ Bulletin @
              • Steelpen2
                • Mar 03
                • 1637
                • HTC Mogul
                Re Grunge Panoramic Style By PB Portrait And Landscape BETA
                oh! eww! wow that's nasty lol hope you fix it soon pb cuz that can ruin ya lol
                  hey pb did you check this out?
                  https://www.smartphonejunkie.org/f551/microsoft-theme-generator-wm6-5-a-192337/
                  • elboriyorker
                    OG Member
                    • Nov 08
                    • 9328
                    • Metro
                    thanks bro lookin into it now
                    SPJ Bulletin @
                    • elboriyorker
                      OG Member
                      • Nov 08
                      • 9328
                      • Metro
                      #11
                      thanks dash that did work. but somehow it was showing like 3 dimension type of craziness hahahah i couldn't see the image or letters properly.
                      SPJ Bulletin @
                        mmm no clue you got a screenie?
                        • PHE-NOM
                          Creativity Unleashed
                          • Oct 14
                          • 1494
                          • htc pro2 baby!!!!!!
                          #13
                          try this bro, i use it all the time.
                          NEW TO SPJ? CLICK HERE
                          NEED TO LEARN HOW TO FLASH? CLICK HERE
                          QUIERES SABER COMO DESBLOQUEAR Y FLASHAR TU TELEFONO? PRESIONA AQUI
                          TIENES PREGUNTAS SOBRE APPLICACIONES O TEMAS, PERO NO SABES HABLAR INGLES? PRESIONA AQUI
                          • elboriyorker
                            OG Member
                            • Nov 08
                            • 9328
                            • Metro
                            #14
                            na i took it off
                            will try that thanks bro
                            SPJ Bulletin @
                            • PHE-NOM
                              • Oct 14
                              • 1494
                              #15
                              just go to the last option (WM5Color Changer) and hit launch, then hit the drop down bar and you want to change the soft key and taskbar background. this lets you customized the color to anything you want.
