Garmin Mobile - Blackberry Bold [Fully Cracked]
Only US maps
Over-The-Air Link
Download and extract file to to a microsd card for your blackberry...pop the card back in your device...and then go to the media icons on blackberry homepage....click on menu button that brings up side menu...click on "explore" and then card memory...and then search for the garmin folder name "G90" and then scroll down to the file with the .jad at the end click on it and it will brind up the download page and hit download and after that completes you will only have to find garmin app on your device and run it and set it up...gps should find automatically!
Only US maps
http://rapidshare.com/files/288425882/G90.rar.html Pass: warez-bb.org
Over-The-Air Link
http://azkafaiz.com/ota
Not sure if it will work on other Blackberries, but to install .jad file, just put it on your SD card and goto media then hit the blackberry button and click on explore. Find the .jad file and install.
Has been tested to work on Blackberry 8900 and Blackberry 8800 series and on a Blackberry Tour, so it would lead me to believe that it would work on all Blackberry devices except for the touchscreen blackberry storm, since the app was not created for touch response
