3.0.45.0429
Xilisoft DVD Creator provides a simple, fast way to convert popular video formats such as convert AVI to DVD, WMV, ASF, DivX, Xvid, 3GP, MP4, MPEG to DVD and burn DVD movie which is playable on home DVD player with the perfect quality.
Xilisoft DVD Creator allows you to specify NTSC or PAL format, adjust 4:3 or 16:9 video aspect, and either burn DVD movie disc or ISO file. The DVD Creator, i.e. DVD maker, is also DVD menu maker which provides so many brilliant DVD menus for your DVD authoring, supports DVD-R, DVD R, DVD-RW and DVD RW. No DVD maker supports so comprehensive video formats like Xilisoft DVD Creator! So easy to use and fast than ever before, just one click to burn DVD movie or convert AVI to DVD, MPEG to DVD!
There has been no DVD burner supporting so comprehensive video formats including AVI, MPEG, WMV, DivX, Xvid, VOB, 3GP, MP4, etc., which means that the Internet will become storehouse of your home theater! And compared with other application, Xilisoft DVD Creator has more features attracting your eyes.
Main Functions:
- Convert AVI, MPEG, DivX, WMV to DVD, burn video files to DVD, like burn AVI, MPEG, DivX, WMV to DVD;
- Convert videos to DVD from AVI, MPEG, WMV, DivX, XviD, MP4, DV, VOB, ASF, 3GP, NUT, YUV, H.264 AVC, M4V files; (V3.0 Updated)
- Support creating DVD movie disc with adjustable DVD menu;
- Burn DVD movie disc, DVD folder, ISO files.
Key Features:
- Provide more friendly interface in DVD Creator V3.0;
- You can trim any segment of a video to burn DVD movie; (V3.0 Added)
- Provide many brilliant DVD menus for choice to burn AVI to DVD and you can edit the menu by setting background music, image and adding the menu topic; (V3.0 Updated)
- Xilisoft DVD Creator supports DVD-R, DVD R, DVD-RW, DVD RW, DVD R DL, DVD-R DL, DVD-RAM, DVD-5 and DVD-9; (V3.0 Updated)
- You can set any segment or frame of a title as its video miniature in menu; (V3.0 Added)
- Support video preview before creating DVD; (V3.0 Added)
- You can set the actions after burn video files to DVD; (V3.0 Added)
- High-quality and fastest converting engine inside to help on how to burn AVI to DVD, and from other formats;
- It supports creating DVD movie with menu skipping to directly play main movie; (V3.0 Updated)
- Provide two modes to display loaded files: thumbnail mode and list mode;
- Offer multithreading and batch conversion;
- Provide >200% converting speed, so fast beyond your imagination.
ADMINISTRATOR@SPJ HIT THANKS ON THE WAY OUT
