Off Remote v1
  • MikeyD
    Find Em Hot Leave Em Wet
    • Apr 25
    • 1609
    • TP2, omnia, Mogul
    • Can You Hear Me Now
    Off Remote v1
    Requirements: · Windows Mobile 5/6 & wifi connection
    Overview: Off Remote is the new Windows mobile version of the popular iPhone application.Off Remote! lets you turn off your PC or Mac directly from your smartphone.No need to walk into the next room to turn off the media device.No need to get up when you forget to turn off the office computer.
    - Off, Sleep, Restart, Lock and Hibernate (not all computers can hibernate)
    - See which computers are currently turned on.
    - Turn them off or put them to sleep.
    - Save power And effort!
    - Control any number of computers on your local network.
    - Compatible with Windows XP, Vista and Windows 7
    - Compatible with Mac OS 10.5 and later
    - Password protection
    - Simple setup - Off Remote uses Bonjour to connect over your local network to the helper on your computer.
    Display Dimensions
    240 x 240, 240 x 320, 240 x 400, 320 x 240, 320 x 320, 400 x 240, 480 x 640, 480 x 800, 640 x 480, 800 x 480
    http://www.handydev.com/index.html
    Download:
    http://depositfiles.com/files/lrm3sme4d
    Can't Access Something Click Here
    Can't Find Something Click Here
    Need Help, Check Out the Help Desk Click Here
    IF SOMEONE HELPS YOU HIT THE "THANKS" BUTTON
    FOLLOW THE RULES
    AND PLEASE CLICK INSTALL ON ALL APPS AND THEMES
    PLEASE POST SOMETHING, ANYTHING HERE
