Update for HTC Diamond2 Power LED Notification
This update for the HTC Diamond2 allows you to see the battery charging status right from the LED. Now enhanced to illuminate green when fully charged, with a quick look you will know when your phone is powered and ready to go.
Installation Instructions:
Note: This Update only can be applied for ROM version between 1.36.XXX.X to 1.44.XXX.X and 1.66.XXX.X to 1.76.XXX.X
Installation instructions
Follow the instructions below to download and install the update on your device:
1. Make sure you have Microsoft ActiveSync installed on your Windows XP PC or Windows Mobile Device Center on your Windows Vista PC. You can find Microsoft ActiveSync from this link or Windows Mobile Device Center from this link.
2. Connect and synchronize your device with your PC via Microsoft ActiveSync or Windows Mobile Device Center using the USB cable.
3. To download this update select the update below and the location closest to you then click Download.
4. Copy the update, which is an .exe file, to your device. To install the update, tap the .exe file and follow the on-screen instructions.
Note: If you perform a device hard reset, you will need to reinstall the update after the hard reset.
source info HERE
source info HERE
