Vibration pattern for Incoming Calls and SMS
    [RELEASE] Vibration pattern for Incoming Calls and SMS
    Hi guys take no credit for this found here
    http://forum.xda-developers.com/showthread.php?t=569025
    Hallo,
    I have wrote a Program to change the vibration pattern for incoming calls and SMS.
    !!! Use this tool at your own risk !!!
    Feature:
    - separately config Phone and SMS
    - Vibration pattern set for Phone and SMS separately
    - SMS vibration set in lengths in different
    - In what will be Profiel Vibrates
    - Choose a Vibrator
    - Cab-File that install the Programm
    Contents of the cab:
    VIBRO.EXE -> background program that monitors the incoming call(Always run)
    VIBROCFG.EXE -> Configuration Utility to Edit the INI file (Only about configuring)
    VIBRO.INI -> number of the vibrator, Profile, Vibrationpattern
    Some DLL
    How To...
    - Install the CAB on the Device
    - Run VIBROCFG.EXE
    - Setup Pattern -> Vibrate,Break,Vibrate,Break in ms
    - Setup Profile -> In what is to be vibrated Profile (You can see the active Profile in your Phone, under the Profilesettings)
    - Setup Vibrator-Nr -> Which vibrator works vibrate. Mostly the highest number.
    - Configure SMS
    - Press Exit in the Menu and the Programm Save the INI and start the VIBRO.EXE
    - Close VIBROCFG.EXE
    Note:
    If the INI file has been modified VIBRO.EXE must be restarted. This makes the CFG program when saving data.
    This Programm is my First APP I programm on the PPC, so it's not perfect. Please give me feedback as it works for you.
    V0.4
    - CAB File Install a shortcut into Startup to start at boot.
    - Separate pattern for PHONE and SMS
    - New GUI for VIBROCFG
    - Fix: VIBRO.EXE hide at Startup
    - Fix try: If second call is received, vibrate, no. (Can not test it myself)
    V0.3
    - Vibration for SMS(no MMS,EMAIL) (The length of the sound file specifies the length of vibration)
    - SMS vibrate: Set Vibration in the Start->Settings->Notification->New SMS->Vibrate=On
    - SMS vibrate at the same Profile as the incoming call(Set in VIBROCFG.EXE)
    V0.2
    - New Config-GUI
    - In English
    V0.1
    - First Version
    ADMINISTRATOR@SPJ HIT THANKS ON THE WAY OUT
    Re: Vibration pattern for Incoming Calls and SMS
    works as stated and is going to be very nice in class since the vibrate can be viscious and loud so i can make the vibrate small ones so its quiet hahahahaha
    • mispook08
      • 3014
      • HTC Vogue (Sprint Touch)
      Re Vibration pattern for Incoming Calls and SMS
      Nice going to install this as well since stock vibration does vib loud thanks for feedback bro . God where is the unlocker !!!!!
        Re: Re Vibration pattern for Incoming Calls and SMS
        thats what im saying they said today the past 4 days..... hopefully it really is
