Hi guys i take no credit for this found here
Titanium-Hero Sense UI[/b] (freeware)
Requirements: WM 6.5
Overview: Turn your titanium to become htc hero
Nitrogen Skin
click the album left & right side to vol up & down
ThrottleLock skin (just in case your WM6.5 homescreen lock not working and you would choose ThrottleLock to achieve the same effect)-get it HERE
you need install the latest mortscipt (the developer has used the 4.3b14), try search HERE
S2P or Nitrogen for the Music plugins
Titanium Hero Pack-V0.5 (7-10-09)
install all the files in the zip, then restart!
if you have install CDigitalClock, CHeroClock, CLauncher, CS2P or CComm, you have uninstall all of these FIRST!
maybe sometime that not very reactive and get error, try to click the button again
for now the developer is trying to make it work with JML Panex, hope that make the plugins more reactive
Titanium Hero Pack-V0.6 - Use JML Panex for the button Function(12-10-09)
you need uninstall all file from v0.5
Install the JMLPanex to Main memory before install the Hero Pack
install all the files to Main Memory, then restart!
Enjoy!
some Problem:
QVGA Portrait ONLY
the scrolling area, only work around top & bottom 15 px
not compatible to other plugins
the developer is not sure, but it only work on WWE rom
only install to main memory
all the plugins need mortscript to check the status, it may cause more memory need
v0.5:
Mirror fpr v 0.5:
v0.6:
Mirror for v0.6:
Nitrogen Hero theme:
JMLPanex:
SENIOR ADMIN@SPJ
http://forum.xda-developers.com/showthread.php?p=4649237
Nitrogen Skin
Enjoy!
some Problem:
QVGA Portrait ONLY
http://forum.xda-developers.com/showthread.php?t=566731&highlight=sense+UI
v0.5:
http://rapidshare.com/files/289776265/Titanium-HeroPack_v0.5.zip
http://www.sendspace.com/file/pk2erx
http://rapidshare.com/files/291979563/Titanium-HeroPack_v0.6.zip
http://www.sendspace.com/file/nk4s78
http://rapidshare.com/files/300934857/Nitrogen-HeroTheme.zip
http://rapidshare.com/files/300934858/JMLPanexV2.10.cab
SENIOR ADMIN@SPJ
