[ROM][KITCHEN] eRice CleanROM and Kitchen ~WM 65 Build 21872 w/ Sense UI
    I take no credit for this. Thanks to eRice and all his work. Original thread can be found here....
    http://forum.ppcgeeks.com/showthread.php?t=93957
    "I'm clean and neat, and I like my ROMs to be too."
    Current Build: 21872.5.0.71 WM 6.5
    Verified working with Sprint and Telus devices!
    This kitchen is built in Ervius Visual Kitchen 1.8.1. Please follow the instructions to build a ROM with confidence!
    How to Build:
    1) Extract the Kitchen and open "Start eRice Kitchen"
    2) In the top left corner, click "Load ROM"
    3) Open "eRice21872.erv". This will automatically load the default values for the kitchen.
    4) Click "Create ROM" to begin building
    5) The flashing utility will automatically start when ROM is ready to be flashed
    How to add EXTs (OEMs):
    1) In the kitchen folder, navigate to EXT>Rhodium>COMMON>Applications
    2) Drop your favorite/downloaded EXT files in this directory
    3) Open "Start eRice Kitchen" from the main kitchen folder
    4) Click "Load ROM" and open "eRice21872.erv"
    5) Scroll to the bottom, and look for the COMMON: Applications category. Here you will find your EXT that has been added to the list
    6) Double click to enable (Green) or double click again to disable (Grey)
    7) Continue creating normally
    Creating OEM from CAB:
    1) Open OEMizer (attached below). In the Folder field, type the name of the OEM folder you would like to use. In the Name field, type the name of the OEM itself. Typically these will be the same.
    2) On the left hand side, make sure "Files and Shortcuts" is checked and highlight it. At the top click "Import Cab".
    3) Open the CAB file you are converting. Click OK on any windows that pop up until you're back at the main window.
    4) Click "Create OEM" in the top left corner. A DOS box will pop up and convert the cab to an OEM folder. This file will be on your desktop apart from the OEMizer folder. Typically it is labeled "OEM" with the actual newly created folder inside.
    5) Use this folder for the next set of instructions.
    Creating EXT from OEMs:
    1) Download and extract EXT_Packages_Builder.
    2) Drag and drop the OEM folder you want to convert onto the .EXE
    3) The package builder will convert the folder into EXT style
    4) Place the newly converted EXT folder into EXT>Rhodium>COMMON>Applications (or whatever category it fits into)
    ~ If you enjoy my work as much as I do,
    I would never say no to a drink or two! ~ :-)
    Screenshots & Changelog:
    Changelog:
    PHP Code:
    v1.2 Changes:
    * Fixed charging proble when plugged/unplugged and LED lights not working correctly
    * Updated some EXTs
    * Added latest Arcsoft to kitchen so dont have to download separate
    * Cleaned a few more things internally
    v1.1 Changes:
    * Returned to stock Sprint OEM Drivers 1.21.651.3
    * Fixed softkey and onscreen keyboard pullout button from working normally
    * Arcsoft has been fixed for Sprint as EXT and uploaded to post #3
    * Fixed some start menu icons not displaying correctly
    * Changed DeviceID to RHOD***** for all device types
    v1 Changes:
    * Updated to WM 6.5 21872 build
    * Added new OEM/Driver base from USCC 1.75
    * Cleaned up EXTs
    * Fixed Sprint Updater
    * Created generic data connection names (instead of Sprint, "3G Data")
    * Changed to "HTC: Quietly Brilliant" Bootscreen
    * Added some EXTs from TP1 kitchens
    PHP Code:
    v1
    SYS
    AdobePDF_2_5_1_0_378273_01B
    AdvancedNetwork_1_0_10_3
    aGPSConfirmation_1_0_19174026_00
    Album_3_0_19181324_0
    AppServiceMsg_1_12_0_0
    App_Service_1_70_0_0
    AudioBooster_2_2_19174121_0
    AudioManager_Eng_1_7_19181424_h
    BluetoothSetting_2_11_1_0
    BootLauncher_1_0_19152530_1
    ButtonSetting_3_17_0_2
    Calculator_1_0_19172021_00
    Camera_6_17_35696_0
    CDMA_RSSI_PPC_1_28_0_0
    ClearStorage_1_40_0_3
    CM_Guardian_Service_1_20_0_0
    CommManager_2_9_11_0
    ConcurrenceMgr_1_5_19142726_00
    ConnectionSetup_3_1_19181321_00
    ContactUtilityEngine_1_0_19161527_0000
    DataDisconnect_1_14_0_0
    DataRoamGuard_1_20_0_1
    DeviceInfo_1_39_0_2
    DialerMenuExt_1_11_0_1
    DMRouter_2_48_0_0
    DRMMiddleware_1_5_19142824_00
    DShow_2_0_19171226_00
    EnableNitz_1_10_0_1
    EPST_4_67_0_0
    FacebookEngine_1_0_19172627_00
    FieldTrial_4_23_0_1
    Field_T_e_s_t_2_19_0_0
    FolderViewer_1_0_18221231_1
    Fuart_1_14_0_1
    FullScreenPlayer_1_6_19152225_00
    GMM_Customized_1_0_0_0
    GoogleLocationService_1_0_1_12
    GSensorCalibrator_1_1_18212730_4
    HACSetting_1_0_2_1
    HTCAnimation_1_3_5_0
    HTCApplication_1_14_1_0
    HTCFontLink_1_0_19132133_1
    HTCFramework_1_1_19172531_00
    HTCGeoService_1_0_19181330_00
    HTCMessage_1_07_281_1
    HTCScroll_2_0_19153028_1
    HTCSettings_1_4_3_0
    HTCStartUp_1_7_0_0
    HTCUtil_4_12_0_2
    HTC_EmailSetupWizard_2_0_19174123_30
    IME_Engine_Western_2_1_19174129_00
    IME_EzInput_Western_2_1_19174126_00
    initProv_2_57_0_1
    InvokeSIMMgr_1_12_0_1
    LaunchDMRouter_1_10_0_1
    LockScreenAppLauncher_1_0_1917_2626
    LockStreamDRM_1_2_081216_O9_05
    LongPressEndKey_1_2_19143124_00
    MediaToolkit_1_0_19181324_00
    MenuEnhancement_1_0_19174130_01
    Message_Enhancement_1_1_19173323_01
    mHubVO_1_75_090515_X0
    MicrophoneAGC_0_91_0_6
    ModeSwitchMsg_1_23_0_2
    ModeSwitchRIL_1_10_0_0
    MP3Trimmer_1_2_19171125_2
    Mute_1_1_2_0
    MyCPL_3_13_0_6
    NewContactCard_1_0_19163924_00
    Notification_Enhancement_2_0_1917_1130
    PhoneCanvas_5_27_0_0
    Phonecanvas_MASD_3_40_1917_3832
    PhoneExt_Service_2_46_0_0
    PhoneSetting_1_46_0_0
    PictureEnhancement_1_50_19171326_00
    PKG_1_1_0_0
    PowerOffWarning_2_12_0_0
    Power_2_26_0_0
    Power_Service_2_23_0_3
    ProgressMenuExt_1_11_0_0
    QuickGPS_1_01_19153726_05
    RandomAccess_4_1_19163625_0
    Redial_1_3_0_0
    ResourceProxy_1_0_19162229_00
    RingtonePlugin_1_0_19143328_00
    RSSHub_2_1_1_1091_03
    RunCC_1_1_6_0
    SensorSDK_4_0_19163322_01
    SetVoiceOnlyUI_1_10_0_0
    SharedModules_1_01_19143331_03
    ShowPhoneNo_1_21_0_0
    SignatureReplace_1_2_0_0
    SIMSecurity_1_14_0_0
    SIM_MGR_6_72_0_0
    SlidingSound_1_2_3_0
    SMSInboxThreading_1_36_0_0
    SMSRetry_Service_1_17_0_1
    SprintDM_DMClientApp_1_1_024_SPCS_R1
    SprintDM_DMClientLib_2_15_0_0
    STK_Service_4_91_0_0
    STK_UIPPC_4_69_0_2
    STK_Worldphone_Reg_1_0_0_0
    StorageLow_1_0_0_2
    StreamingMedia_3_1_19181332_00
    StreamingSrcFilter_2_7_19143024_00
    TaskManager_2_1_19181423_17
    Teeter_1_6_19163530_00
    TimeZoneAutoFix_1_0_19203033_00
    TouchOptions_1_0_19171631_00
    TVOutPopUp_1_2_19142724_0
    TVOutSetting_2_14_0_1
    USBToPCPopUp_2_2_19143124_0
    USBtoPC_1_25_0_0
    USSD_Service_4_34_0_1
    VoiceRecorder_1_10_19171120_1
    VolumeControl_2_1_19163532_0
    Wi-FiWizard_1_8_0_0
    WiFiSettings_1_2_4_0
    WLANSettings_2_6_4_0
    YouTube_2_6_19174121_00
    zlibce_m_1_2_3_0
    APPS
    Additional Themes
    Applications - psShutXP
    Applications System - Wi-Fi Internet Sharing 0.9.2.0
    EPSTLab_4_14_0_0
    File As First Last
    Games - Chess
    Games - Freecell
    Games - Galaga
    Games - Hearts
    Games - Kevtris
    InboxMenuExtensibility
    MS_Facebook_1_0_07_1
    Pocket Sand
    SMS_NoSent
    TouchFLO_3_0_19143222_RW00
    Manila_2_1_38687_2=False§
    Manila_Sense_2_1_19193517_0
    Sprint Updater
    REG
    REGISTRY_FileSystemCache
    REGISTRY_FileSystemCacheFilter
    REGISTRY_FontCache_0x08000
    REGISTRY_SecurityOff
    REG_Zero_press_hold_time
    SDCard Speed Up
    IE6Enhancement_1_0_19202230_00
    Sprint Touch Pro2
    Build 21872.5.0.71
    Downloads:
    - Download the eRice Kitchen here: eRice Kitchen v1.1
    Download the latest COM3 Upgrade Pack here: 23081 COM3
    Download the latest COM2 Upgrade Pack here: Not yet available
    - Download the CleanROM here: eRice CleanROM v1 (Sprint Only)
    A few notes:
    1) Please make sure your phone is unlocked. You can find more information about that here.
    2) The kitchen is considered to be carrier generic, however, since I only have a Sprint device I can't test it on other networks. If you try, please report how everything functions.
    3) I will try to keep up with questions as best as I can.
    4) Please report any bugs you encounter in the kitchen and resulting ROM
    Known Bugs:
    * Sometimes when plugged in, the battery icon doesn't change to charging symbol and the charge light doesn't come on. (Working on it)
    Special Thanks:
    MightyMike
    JooJooBee666
    Juicy47
    cmonex (for HSPL)
    superevilllama
    ervius
