Dj’it is an application for your cell phone that turns it into a music console. It’s the ideal solution for music lovers that want to take their parties on the road, and be able to preform advanced tasks, such as composing and mixing, on the go using their mobile phone.
Whilst still in the development phase, it promises to bring live dual-track mixing directly from your music library straight from your phone. Therefore you have the ability to play different tracks in parallel, and mix between them. No need to worry about the volume levels, Dj’it automatically settles the tunes on the some tone so that the transition is smooth and seamless. Moreover, you can use your phone as a compositor to record tracks and blend them in with the ones on your phone.
[DOWNLOAD]http://www.megaupload.com/?d=5LOO5BCP[/DOWNLOAD]
